What's your Fuel Consumption... Gallons per Hour
   / What's your Fuel Consumption... Gallons per Hour #41
Re: What\'s your Fuel Consumption... Gallons per Hour
I'm running a M9000 and have a fairly accurate measure of fuel usage I have a 300 gallon tank that was bought same time as the tractor and have almost 250 hours on the tractor and very close to being empty fuel storage tank so 1.2 gallons per hour over the long haul. I chisel plow, disk, run a hydraulic auger, box blade miles and miles of roads and lots of FEL work and front mounted BTR Grapple gathering brush and trees. I have a Rhino TW72 Shredder but I still haven't even hooked it up to see if it works after over a year and a half, guess I didn't need to mow as much as I thought I did when purchasing it or I'd have forgone the mower and gotten the backhoe.
Steve
   / What's your Fuel Consumption... Gallons per Hour #42
Steve
   / What's your Fuel Consumption... Gallons per Hour #43
Kioti DK35 uses about .6 gal per hour using 6" bushhog.
   / What's your Fuel Consumption... Gallons per Hour #44
   / What's your Fuel Consumption... Gallons per Hour #45
Massey MF-1040 32HP Diesel,4x4, geared, 5Ft Woods Bush hog, about 1 gal/ hr mowing, 1ft-2ft high grass, some steep hills.
   / What's your Fuel Consumption... Gallons per Hour #46
   / What's your Fuel Consumption... Gallons per Hour #47
My 4320 has averaged .7/hr for 225 hours. Most of the time when running the backhoe I go through .6gal/hr. When I am running the MX6 at PTO speed I go through a gallon an hour.
   / What's your Fuel Consumption... Gallons per Hour #48
   / What's your Fuel Consumption... Gallons per Hour #49
My Mitsu D1800 uses 1 gallon a day. It is capable of more work than that but I'm not. /forums/images/graemlins/grin.gif Retirement is great, goodbye crap, hello nap! /forums/images/graemlins/crazy.gif
   / What's your Fuel Consumption... Gallons per Hour #50
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
NEW Woods 6ft Finish Mower (A53472)
NEW Woods 6ft...
LMC LOT NUMBER 144 (A53084)
LMC LOT NUMBER 144...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2015 John Deere 544K Articulated Wheel Loader (A52377)
2015 John Deere...
