What's your Fuel Consumption... Gallons per Hour
   / What's your Fuel Consumption... Gallons per Hour #41
Re: What\'s your Fuel Consumption... Gallons per Hour
I'm running a M9000 and have a fairly accurate measure of fuel usage I have a 300 gallon tank that was bought same time as the tractor and have almost 250 hours on the tractor and very close to being empty fuel storage tank so 1.2 gallons per hour over the long haul. I chisel plow, disk, run a hydraulic auger, box blade miles and miles of roads and lots of FEL work and front mounted BTR Grapple gathering brush and trees. I have a Rhino TW72 Shredder but I still haven't even hooked it up to see if it works after over a year and a half, guess I didn't need to mow as much as I thought I did when purchasing it or I'd have forgone the mower and gotten the backhoe.
Steve
   / What's your Fuel Consumption... Gallons per Hour #42
Steve
   / What's your Fuel Consumption... Gallons per Hour #43
Kioti DK35 uses about .6 gal per hour using 6" bushhog.
   / What's your Fuel Consumption... Gallons per Hour #44
   / What's your Fuel Consumption... Gallons per Hour #45
Massey MF-1040 32HP Diesel,4x4, geared, 5Ft Woods Bush hog, about 1 gal/ hr mowing, 1ft-2ft high grass, some steep hills.
   / What's your Fuel Consumption... Gallons per Hour #46
   / What's your Fuel Consumption... Gallons per Hour #47
My 4320 has averaged .7/hr for 225 hours. Most of the time when running the backhoe I go through .6gal/hr. When I am running the MX6 at PTO speed I go through a gallon an hour.
   / What's your Fuel Consumption... Gallons per Hour #48
   / What's your Fuel Consumption... Gallons per Hour #49
My Mitsu D1800 uses 1 gallon a day. It is capable of more work than that but I'm not. /forums/images/graemlins/grin.gif Retirement is great, goodbye crap, hello nap! /forums/images/graemlins/crazy.gif
   / What's your Fuel Consumption... Gallons per Hour #50
New Long Forks (A53002)
New Long Forks...
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A52377)
2017 Ford F-350...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2020 INTERNATIONAL...
UNUSED GREAT BEAR 1.5CY SELF DUMPING HOPPER (A51248)
UNUSED GREAT BEAR...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A53472)
2022 MAXXD BD14...
2015 JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
2015 JCB 525-60T4...
