- Joined
- Aug 31, 2001
- Messages
- 65,864
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
No. Think of it this way...OK, but if you allow them to travel at different speeds, wont it loose traction when one wheel either lifts or has no grip ?
If you have two or more wheel motors in series and they're driving along and all of a sudden one gets lifted off the ground or spins in mud what happens?
As that 'loose' wheel motor tries to spin, it cannot draw more hydraulic fluid through the motor behind it, nor push more fluid through the motor in front of it because it has no load. The other motor(s) that is(are) not losing traction will immediately build pressure and keep turning.
Or something like that.
My machine has 4 wheel motors and is articulated in the middle.
The left front and right rear wheel motors are in series.
The right front and left rear wheel motors are in series.
Both of those series circuits are in parallel with each other.
When you articulate the machine to the left, for example, the two left wheels roll towards each other and the two right wheels roll away from each other.
So if you think about it, as you turn left, the left front wheel and the right rear wheel are rolling backwards as the right front wheel and left rear wheel are rolling forward.
If you want 6 wheel motors, three to a side, and you want a pivoting axle, you're going to have to account for that somewhere. Same as if you want it to articulate.
Make sense?
