Where do you hook your chain for pulling trees?
   / Where do you hook your chain for pulling trees? #1
lzicc
Platinum Member
Pittsburgh, Pa
Kubota B2650
I have a BH and FEL on my tractor. To pull roots and all out from a tree, I want to leave about 12' of the trunk, tie a chain to the top of the trunk and use the height of the tree for leverage to pull roots and all out. What is a good place to attach the chain to the tractor? I don't want to attach it to the BH or FEL bucket since that could possible damage them.
   / Where do you hook your chain for pulling trees? #2
My tractor has a bar protruding out from the frame that I call a "draw bar". Not sure if that's the proper name but it's got a couple of holes in it and sticks straight out. I have a chain shackled to it that I use to pull out trees. Get a nice long, sturdy chain with a chain hook on the other end and wrap it around the tree 2 or 3 times and lay the hook over one of the links. Slowly take out the slack and pour the coals to it. Make sure your chain is longer than the tree is tall or else you'll be wearing the tree.
EDIT: I just noticed that you have a backhoe. It might be in the way.
   / Where do you hook your chain for pulling trees? #3
Do you have chain grab hooks installed on your FEL Bucket?
Personally I use chain grab hooks installed on the FEL and clevis grab hook installed on center drawbar as chain attachment points more or less interchangeably, but I favor the center drawbar attachment point for heavy jobs.
Your L4060 and my L3560 are both heavy frame tractor-loaders; I have optional L2296 Heavy Duty Round Back Bucket on my LA805 FEL.
Sometimes it helps to wiggle tress by curling bucket before pulling on them. Sometimes it helps to drive FORWARD, then CAUTIOUSLY lift/curl with the bucket before pulling.
A Ratchet Rake attached to bucket increases bucket purchase on tree trunks at about operator shoulder level. If you have a lot of trees to push over Ratchet Rake will save you time.
For readers WITHOUT a Backhoe, be sure to mount a counterbalance on the 3-Pt hitch before applying force via bucket chain grab hooks.
LINKS:
CountyLine® Drawbar Hook - Tractor Supply Co.
http://www.extension.org/sites/default/files/English Task Sheets Group 6.pdf
   / Where do you hook your chain for pulling trees? #4
I used to pull over trees with an old JD B tractor by leaving about an 8' high stump using the drawbar w/clevis hook/chain. Usually have to work it back and forth. All trees/root systems are different... but don't think you will routinely take out anything bigger than 6-8" tree this way. Hooking anywhere else higher on the rear, or even this using of the drawbar... can cause an instant ROPs test if/when the tires bite and she trys to flip over. So be real carefull.
   / Where do you hook your chain for pulling trees? #5
I hook a chain to the drawbar for pulling.
   / Where do you hook your chain for pulling trees? #6
Use your rops no matter which way u try to remove the stump
   / Where do you hook your chain for pulling trees? #7
Sorry about that, use the rops for protection not pulling. Suggest using draw bar as center of gravity is lower. Best to put old jacket or something like that over the chain in case it breaks.
   / Where do you hook your chain for pulling trees? #8
Please tell me you didn't...
To late...you did... ;)
I had to re read that. :)
I can use the draw bar, but I don't know if I can put the drawbar on while the BH is still on or not. Plus the chain coming from the DB would put pressure on the bottom of the BH. I do have bucket hooks and the HD Bucket but didn't want to exert allot of pressure on the FEL. I may have to yank the tree a little.
2014 Ford Explorer AWD SUV (A53424)
2014 Ford Explorer...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
PAIR OF 5' PIN ON FOLD UP RAMPS (A54756)
PAIR OF 5' PIN ON...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2018 JLG 3246ES 32ft Electric Scissor Lift (A55787)
2018 JLG 3246ES...
2015 Peterbilt 337 Pac-Mac KBF-20H Forestry Grapple Truck (A55788)
2015 Peterbilt 337...
