Where do you hook your chain for pulling trees?
   / Where do you hook your chain for pulling trees? #11
FTR...if it's a difficult pull, I pull only from the drawbar.
   / Where do you hook your chain for pulling trees? #12
I'd recommend using only the drawbar...good strength and low center of gravity...using the FEL, I fear, would leave you with too much pressure and torque or destroy something up front.
I'll see if the DB can stay on with the BH attached.
   / Where do you hook your chain for pulling trees? #14
Just curious as to how you plan on setting a chain 10-12' high in a tree?
Doug in SW IA
   / Where do you hook your chain for pulling trees? #15
Backhoe on the tractor??
Use it, dig around the stump, use the boom and bucket curl to push the tree over and drag it from the drawbar.
My JD4200 has a drawbar under the backhoe that I use.
   / Where do you hook your chain for pulling trees? #17
If you have a back-hoe:why don't you just dig the stump out.I wouldn't make a pull like that with the FEL.
I doubt that you can have the draw bar installed with the BH on.
   / Where do you hook your chain for pulling trees? #18
I now mostly use a chain and brush grubber attached to the drawbar, but when I had my BX, I used to pull small trees out with a tooth bar on the loader. I would push them over with the loader weakening the roots, then pull it out using the toothbar and bucket curl.
   / Where do you hook your chain for pulling trees? #19
Egon is on to something here. The BH can loosen up the roots enough that you can knock a tree like that over with the FEL, or pull it as Gary describes. Don't try this with dead trees or ones with widow-maker branches, though. Are you cutting the tree 10-12 feet up or is that just where you're setting the chain using a ladder or something?
This is just me, but after trying many different methods, including the chain-pulling approaches mentioned here, I've found simply felling the tree and grubbing out the stump with the backhoe is generally the safest approach, even though it may take longer. If you make the felling cut a few feet up, it gives the backhoe more leverage to release the stump.
   / Where do you hook your chain for pulling trees? #20
There are 2 points on a tractor designed for pulling. The drawbar & 3point. The drawbar is the best as its solid & low. Anywhere else increases the chances of breaking something or rolling over.
And has been said, ROPS up & seatbelt on for safety.
New/Unused 72in Quick Attach Brush Cutter (A54865)
New/Unused 72in...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51692)
2013 Mitsubishi...
VOLVO L70H WHEEL LOADER (A52706)
VOLVO L70H WHEEL...
Giyi Stump Grinder (A53316)
Giyi Stump Grinder...
Self Dumping Hopper (A53316)
Self Dumping...
