Where do you hook your chain for pulling trees?
   / Where do you hook your chain for pulling trees?
Just for fun, here is my crazy wife on the lift limbing the trees. She is so awesome.
   / Where do you hook your chain for pulling trees? #42
If the situation allows, don't cut the tree and then try to remove the stump.
Cut some roots, then push or pull the tree over, and the stump comes up attached to the tree trunk.
That's what windstorms usually do, and they have had lots of experience. :)
Bruce
That method works well. I've done it that way quite often.
   / Where do you hook your chain for pulling trees? #43
I was just over at my neighbors trying to pull out an oak stump(24" minimum in diameter) that was cut at about 18" above grade. I had dug around it with my B26 TLB but it seems to have a bunch of vertical roots that I cant get to. I had my LS P7010 with chain hooked to drawbar, RPM at 1000 (just above idle) and in low range 1st gear just creeping and broke my 3/8" grade 70 chain. It just separated the link at the hook. The chain popped back a bit but not a lot. The loose links didn't reach back to the stump even.
I am going to try digging out some more with the backhoe, but if that doesn't work, I am looking for suggestions.
   / Where do you hook your chain for pulling trees? #44
I was just over at my neighbors trying to pull out an oak stump(24" minimum in diameter) that was cut at about 18" above grade. I had dug around it with my B26 TLB but it seems to have a bunch of vertical roots that I cant get to. I had my LS P7010 with chain hooked to drawbar, RPM at 1000 (just above idle) and in low range 1st gear just creeping and broke my 3/8" grade 70 chain. It just separated the link at the hook. The chain popped back a bit but not a lot. The loose links didn't reach back to the stump even. I am going to try digging out some more with the backhoe, but if that doesn't work, I am looking for suggestions.
that,s why one should use a chain rather than a cable. breaking cables tend to whip!
my suggestion would be a stump grinder.
   / Where do you hook your chain for pulling trees? #45
Keep digging Gary. If you go done one bucket with you'll get to the point where you can slice off the tap root with the bucket and curl.
   / Where do you hook your chain for pulling trees? #46
If you like your tractor and value your life, forget the chain. Go to block and tackle systems using a deadman and your tractor connected to the tree. DISTANCE yourself and your machine. Hint. You don't need to hang a block right close to the tree. You can hang a chain or cable however far you want from the tree and then put your blocks on at that point. Work slow, work smart.
   / Where do you hook your chain for pulling trees? #48
c4 or rdx would be my choice!
Ya beat me to it, Stargazer.
My wife and I are always saying to each other, while watching TV, "Why does everyone have C4 except us?"
   / Where do you hook your chain for pulling trees? #49
Here's how I do it. I just push the trees over with the tooth bar on the loader bucket, then drag them out where I can cut them up.
   / Where do you hook your chain for pulling trees? #50
Try hooking the chain around a root on one side, wrap the chain around the other side of the stump so you are twisting the stump as you pull. The twisting can help break tap roots.
FAKE (A52472)
FAKE (A52472)
2025 GIYI GY-BK56M 56in Excavator Boom Skid Steer Attachment (A55787)
2025 GIYI GY-BK56M...
UNUSED FUTURE VR39 - 39" MINI HYD VIBRATORY ROLLER (A54757)
UNUSED FUTURE VR39...
2015 Ford F-150 Ext. Cab Pickup Truck (A55788)
2015 Ford F-150...
2000 Ford F-550 Altec AT35-G 35ft Bucket Truck (A53422)
2000 Ford F-550...
COUNTER WEIGHT (A54756)
COUNTER WEIGHT...
