Where is a good place to get self tapping deck screws for trailer?
   / Where is a good place to get self tapping deck screws for trailer?
After working on this for a couple of days in the afternoons (of course the hottest time of the day), I've discovered that the earlier pictured self tapping screws from Lowes perform far better than the original #30 Torx screws.
I found a local nut and bolt store and took a couple of the original bolts with me and bought exact replacements along with a good drill bit to drill pilot holes. My experience with this; a disaster! I toasted so many drill bits that the store called the manufacturer to ask why. I'm using a 36v DeWalt drill and am applying over 200 pounds of pressure yet the drill bits are toast after only a couple of holes. Trust me, I've drilled many thousands of holes in steel over the years. Something was wrong.
The bit manufacturer said that I had to remove the wood decking and drill only through the steel; not through the wood and then the steel. They said the wood holds the heat in and the bits burn up. Well, true enough, when only drilling through steel, the bits seemed to perform fine. However, there is no way I'm taking all the boards off and drilling them separately from the steel channel under them and trying to make sure all lines up! My thought on this is 'unacceptable'.
What surprised me was the screws from Lowes that are made to go through wood and then steel worked just fine. They went through the lumber and then 3/8" steel no problem with tight threads that sucked the lumber down tight. They far outperformed the original method. The screws are so hard that I shattered 2 of the #2 plus (blue looking) bits but never stripped a single screw head. I'd never shattered one of those #2 plus bits before.
I was only going to replace the 12' section of the 20' wood decking. However, now with the 12' section replaced the front section looks really bad with some gaps as wide as 1 1/2" between the boards. I just checked the prices and it will cost me $81.84 for the treated lumber and enough screws to replace the front half as well. I guess I probably ought to do that while I'm at it. The issue is that it's supposed to get up to 103 degrees here today with high humidity, putting the 'heat index' close to 130 degrees. Maybe not in the cards for today.
I just thought I'd report on my experience with the deck screws for trailers. I honestly did not expect the screws that drill through steel to be the best bet and to be far better than replacing with the original screws. I didn't know that the drill bit manufacturers refuse to warrant their bits when you drill through lumber first. I'd never considered the lumber causing excessive heat on the bit tip and ruining them almost immediately.
**It's those exact screws that "Kebo" posted from Lowes that ended up being far better than the original setup**
   / Where is a good place to get self tapping deck screws for trailer? #22
Like you Dargo I have had great luck with the screws from Lowes. I have been using them for about 12 years since I re-did my first trailer and have never needed to look anywhere else. Just stuck with what worked.
Chris
   / Where is a good place to get self tapping deck screws for trailer? #23
Dargo,
I have started the same type of project you described. Can you provide any more detail about the screws that you bought at Lowes? I have already used screws I bought at Home Depot on the entire trailer deck. After the first trip up north, every one of the screws has backed out several threads leaving my decking loose on the trailer frame (aluminum). I can't imagine having to deal with this after/berfore every trip in the future. I am searching for a better alternative.
Thanks.
   / Where is a good place to get self tapping deck screws for trailer? #24
Dargo,
Thanks.
Did the screws back or did the wood shrink? If the wood was wet, and dried out, it can shrink making it appear that the screws backed. I have seen this on house decks, and it is particularly troublesome with nails.
There is a post above that talks about letting the wood dry before putting it on the trailer and I think it is a good idea.
   / Where is a good place to get self tapping deck screws for trailer? #25
You have made a very good point. Now that I have retigthtened all of the screws, I will monitor them on my next trip this weekend. I had assumed that they backed out due to road vibration, however, it could very well be due to the wood shrinking.
I replaced beat up 3/4" PT plywood, which was riveted to tralier frame, with 2X6 PT lumber. Due to the additional thickness, I opted for self drilling screws designed for attaching would to metal.
Thanks for you advice.
   / Where is a good place to get self tapping deck screws for trailer? #26
I have purchased stainless steel self-drilling screws for my PT plywood
deck from stainless-fasteners.com, and they worked great. There
are other online sources, and they can be quite a deal.
   / Where is a good place to get self tapping deck screws for trailer? #28
I just replaced the floor in a 16 ft. flatbed. I had to drill a pilot hole first. I got my screws at Tri-state. I ended up using a cordless impact gun with a star head to seat the screws because my drill could not handle it. good luck
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
2017 Freightliner MT55 Step Van (A56858)
2017 Freightliner...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56436)
PENDING SELLER...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2021 Chevrolet Silverado 1500 Pickup Truck (A56858)
2021 Chevrolet...
