Where to buy unusual size U-bolt?
   / Where to buy unusual size U-bolt? #1
schweizer
Southern Oregon
Kioti DK45SE Hst
Probably an easy answer? I'm just looking for a 3" wide U-bolt for attaching stuff to my ROPS. (Kioti DK45) Up until now I've used hose clamps to attach fire extinguisher and lights, but I'd like to build a sun shade out of fiberglass and plywood, and attach it with U-bolts. Reasonable? Local hardware stores don't have 3" wide. Any online outlets that you use? Thanks.
Marcus
   / Where to buy unusual size U-bolt? #2
Get some all tread and one inch flat bar and make your own.. I do it all the time.. Lou
   / Where to buy unusual size U-bolt? #3
Yes. ... Be sure to grind off the threads in the area of the bend. Otherwise you risk cracking in the stress riser at the root of each thread.
larry
   / Where to buy unusual size U-bolt? #4
Marcus
I get them from Agri-supply Agri Supply - Search
Instead of using plywood for your canopy you might consider something like 'divinycell'...it is a closed cell PVC foam that when laminated/encapsulated with fiberglass it is as strong as plywood and weighs about 95% less...I'm currently fabricating one myself...
Good ideas. Thank you!
   / Where to buy unusual size U-bolt? #6
McMaster-Carr is always a good place to look for hardware.
   / Where to buy unusual size U-bolt? #7
any leaf spring shop should have several sizes on hand.
   / Where to buy unusual size U-bolt? #8
A real good spring shop or 4x4 shop can make their own. But I agree with Lou, get some all thread and make your own.
   / Where to buy unusual size U-bolt? #9
Boat Trailers use a lot of them.
2000 Chevrolet C8500 Flat Bed with a Moffet Kit - CAT 3126 Engine! - (A55301)
2000 Chevrolet...
2025 Swict 84in Bucket Skid Steer Attachment (A55787)
2025 Swict 84in...
Kubota RTV500 (A47384)
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
2001 Blue Bird Commercial Portable Office Bus (A55852)
2001 Blue Bird...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A55788)
2019 Ford F-550...
