Where to buy unusual size U-bolt?
   / Where to buy unusual size U-bolt? #1
schweizer
Southern Oregon
Kioti DK45SE Hst
Probably an easy answer? I'm just looking for a 3" wide U-bolt for attaching stuff to my ROPS. (Kioti DK45) Up until now I've used hose clamps to attach fire extinguisher and lights, but I'd like to build a sun shade out of fiberglass and plywood, and attach it with U-bolts. Reasonable? Local hardware stores don't have 3" wide. Any online outlets that you use? Thanks.
Marcus
   / Where to buy unusual size U-bolt? #2
Get some all tread and one inch flat bar and make your own.. I do it all the time.. Lou
   / Where to buy unusual size U-bolt? #3
Yes. ... Be sure to grind off the threads in the area of the bend. Otherwise you risk cracking in the stress riser at the root of each thread.
larry
   / Where to buy unusual size U-bolt? #4
Marcus
I get them from Agri-supply Agri Supply - Search
Instead of using plywood for your canopy you might consider something like 'divinycell'...it is a closed cell PVC foam that when laminated/encapsulated with fiberglass it is as strong as plywood and weighs about 95% less...I'm currently fabricating one myself...
Good ideas. Thank you!
   / Where to buy unusual size U-bolt? #6
McMaster-Carr is always a good place to look for hardware.
   / Where to buy unusual size U-bolt? #7
any leaf spring shop should have several sizes on hand.
   / Where to buy unusual size U-bolt? #8
A real good spring shop or 4x4 shop can make their own. But I agree with Lou, get some all thread and make your own.
   / Where to buy unusual size U-bolt? #9
Boat Trailers use a lot of them.
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
2004 FREIGHTLINER FL70 FLATBED W/TANK & DITCH WITCH MIXER (A55745)
2004 FREIGHTLINER...
2007 Sterling Acterra Dump Truck (A51691)
2007 Sterling...
Perkins 1791 Power Unit (A53314)
Perkins 1791 Power...
2008 Ford F-450 Service Truck (A53422)
2008 Ford F-450...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
