Where to buy unusual size U-bolt?
/ Where to buy unusual size U-bolt? #1
schweizer
Gold Member
Southern Oregon
Kioti DK45SE Hst
Probably an easy answer? I'm just looking for a 3" wide U-bolt for attaching stuff to my ROPS. (Kioti DK45) Up until now I've used hose clamps to attach fire extinguisher and lights, but I'd like to build a sun shade out of fiberglass and plywood, and attach it with U-bolts. Reasonable? Local hardware stores don't have 3" wide. Any online outlets that you use? Thanks.
Marcus
/ Where to buy unusual size U-bolt? #2
Get some all tread and one inch flat bar and make your own.. I do it all the time.. Lou
/ Where to buy unusual size U-bolt? #3
Yes. ... Be sure to grind off the threads in the area of the bend. Otherwise you risk cracking in the stress riser at the root of each thread.
larry
/ Where to buy unusual size U-bolt? #4
Marcus
I get them from Agri-supply Agri Supply - Search
Instead of using plywood for your canopy you might consider something like 'divinycell'...it is a closed cell PVC foam that when laminated/encapsulated with fiberglass it is as strong as plywood and weighs about 95% less...I'm currently fabricating one myself...
/ Where to buy unusual size U-bolt? #6
McMaster-Carr is always a good place to look for hardware.
/ Where to buy unusual size U-bolt? #8
any leaf spring shop should have several sizes on hand.
A real good spring shop or 4x4 shop can make their own. But I agree with Lou, get some all thread and make your own.
/ Where to buy unusual size U-bolt? #9
Boat Trailers use a lot of them.
/ Where to buy unusual size U-bolt? #11
My 1999 F250 Super Duty 4x4 uses 3" wide leaf springs/ubolts - just got new ones for the rear springs a couple of months ago. The rear bolts have the rounded U and the front springs use the squared U - take your pick and order appropriately.
/ Where to buy unusual size U-bolt? #12
If you want it to look better get some rod and and thread the ends and bend or you could use bolts and a piece of flat steel say 1 1/2 in wide and put two holes in it.
/ Where to buy unusual size U-bolt? #13
Three inch is a common size and should be widely available. Try the already mentioned places or a spring shop will likely have them made and on hand. If you make it as far as a spring shop don't be concerned. Most any I have ever seen look like a throwback to the middle 1800's.
/ Where to buy unusual size U-bolt? #14
You could check an auto parts store. 3" is a common exhaust pipe size.
/ Where to buy unusual size U-bolt? #15
I've got them before for a pipe top trailer from a muffler shop.
hugs, Brandi
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
1981 LINK BELT HSP 8028 (A58216)
1981 LINK BELT HSP...
Unused 2025 CFG Industrial MH12RX Mini Excavator (A59228)
Unused 2025 CFG...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
2017 FORD E-350 SUPER DUTY BOX TRUCK (A60430)
2017 FORD E-350...
UNUSED JCT 72" QUICK ATTACH HYD TILLER (A60432)
UNUSED JCT 72"...
