Re: where\'s mower drive on B6100D
I've been offline for a few days and haven't had a chance to respond.
To my knowledge, Woods does (or at least did) make a mid-mower for the
B6100/
B7100 series tractors utilizing the front electically-actuated PTO clutch. I was even told that the Kubota brand mid-mower for these tractors was actually built by Woods.
The "D" suffix indicates 4wd / Gear Drive. With this "gear drive" model you won't have a live PTO, which means that if you get rear-mounted PTO equipment you'll have to stop and start the PTO equipment every time you depress the clutch to change gears. This may or may not be a serious problem depending upon what work you are doing.
Experience: I have a B7100D (16hp) 4wd gear drive with 48" mid-mower (front PTO). I have found that I like mid-mowers in general, but this particular design is a real pain. Unless you found one real cheap, I wouldn't bother with one. I also have a
B2150 HSD (4wd/24hp 4-cylinder/FEL) that I use an Air-Tunnel 60" Landpride 3-point hitch mower with. To my surprise, my
B7100 handled this mower just fine. The only problem is that the lack of Live PTO is also a pain to deal with with these older gear-drive compact Kubotas (unless you mow in relatively open areas). I use a 42" rotary mower on the
B7100 just fine (in open areas). I once tried a heavy duty 60" model and my
B7100 couldn't even pick it up.
Price: The price varies in different parts of the country. Your profile doesn't indicate which part of the country you live in (your user name implies NJ). If I were in the market to sell my B7100D (which is in excellent shape) my bottom line would be around $4500. It has the mid-mower, a complete set of Turf and Ag tires and a factory ROPS added about 3 years ago.
Hope this helps in your quest to find a good value tractor...
Kelvin
