First one
Thought I had my mind made up on this model Work Saver grapple FLGR-4062S Compact Tractor Grapple .Not knowing to much about them I thought I'd research a little more before buying it this Sat. I wrote to this place and was told for the money I wanted to spend that I should check this model out 60 ROOT GRAPPLE-BUCKET STYLE root rock brush grapple
( ROOT2RG-B60 ) This model has two claws on top. the Work Saver has one .
I really could use some advice on what you think might be the better one.
First ,I should say what I'm going to plan on doing with it. Would like to be able to: rake and pick up brush,limbs ,rocks,logs for fire wood.
The work saver is lighter than the other other which would mean I could lift more. Lower tines are short and only open 27" This is used, but only once you wouldn't know it was off the show room floor it looks that new.
But the ROOT2RG-B60 has the two claws which might hold on to a load better ,but has longer tines, and heavier then the work Saver. This is new and has a 1 year warranty.
Help!!! would anyone take a look at these and let me know what you think before I end up buying the wrong one.
Does the one claw work just as good as the two claw grapple?
Thanks for any advice!!
