Which Valve to get for DIY Power Beyond Kit?
   / Which Valve to get for DIY Power Beyond Kit? #1
HarleyBob
Puget Sound, WA.
I have read MadReferee's explaination of how to run the power beyond valve for adding simple hydraulics off FEL (in my case
for running log splitter on a Kubota L3010). However I want to get the correct valve. I understand it should be single spool, open center but there areother options to consider. Do youknow an exact model (perhaps Prince brand) I would use?
I believe I need a simple On-Off but all the center spring, detents etc are confusing me. I have access to the Prince catalogue and they are sold at Northern Tool and Surplus Center but I am open to anything that is the right way to do it.
I would go to Kubota dealer, but I am pretty remote and it would require a ferry ride on a trailer, more than the cost of the
work.
Thanks.
   / Which Valve to get for DIY Power Beyond Kit? #2
The Prince SV valve is the one you want. It has stackable spools so that you can choose the one or ones you want. You can always add another spool onto it at a later date if you need another.
You will need it to be configured as follows:
<ul type="square"> [*] SVI15 inlet section with adjustable relief set at 2000psi with SAE 8 port
[*]SVE22 outlet section with power beyond and SAE 8 port [*]any one or more of the SVW work sections to suit your individual application. The SVW1BA1 is what you would normally use for a TNT setup or with any double acting cylinder. [/list] Below is a link to the Prince SV catalog section. Surplus Center sells these valves and sections at a very competitive price. They should also be able to help you configure the valve's work sections to suit your application.
Prince SV catalog in pdf format
Thanks MadRef, that is exactly what I was looking for.
I will post my results once I get things done.
Now to decide on a splitter. I lean towards Ramsplitter since
they seem to be built well of all US materials and the
will paint them Kubota Orange (very important!)
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
(1) HD 24ft Free Standing Corral Panel (A57454)
(1) HD 24ft Free...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
case 370 glass door never installed (A56436)
case 370 glass...
Mower King Brush Cutter (A53317)
Mower King Brush...
