Whole house generator
/ Whole house generator #81
I took a different approach than many. I installed a manual transfer switch, which was easy because the main panel is on the barn, and all the house power goes through a single 100A breaker. I also bought a PTO generator. Had to build a frame for it, but that was no problem. About every 5 years we have a 3 day outage, most others are only an hour or so. It takes a good 15 minutes to remove mower and install generator, usually in the rain, but it does the job and I always have fresh fuel and don't worry about an engine that has been sitting 12 months.
I just retired and finally have time to tinker, so I'm going to build up a PTO generator too. I won't need all the engine horsepower, so I'm going to gear it to run on 350 RPM, which should save quite a bit of fuel. I have a tachometer on the PTO, so setting the correct RPM shouldn't be a problem.
I also have an old 2.5" pump that I'm going to set up as a PTO pump. Judging from the number of belts on the sheave, it was originally about a 15 HP pump, and I assume 1800 RPM, though it might run slower. The impeller housing is almost a foot in diameter. I haven't been able to find any data on it on the web. I have seen similar pumps as boosters in high rise sprinkler systems, so think it will put out a lot of water at high pressure.
I have a little 1" 5 HP Honda pump for fire fighting when the power lines burn up, but there's a world of difference between a 1" line at 50 psi and a 2" line at 100 psi.
/ Whole house generator #82
When I built my house in 2006 we had a 15KW Generac Guardian put in. After less than 100 hours the stator burned up and it would cost $2K to fix it so I junked the whole thing and sold the garbage on Craig's List. According to what I read the stator problem is common with Generac which mine was only guarenteed for two years. Now it is up to three.
I just finished installing a 20KW Cummins Onan, whole house transfer switch and a new load center. This thing is wonderful and quiet. 62 decibles running full tilt. You get what you pay for and this one is guarenteed for 5 years/2000 hours.
/ Whole house generator #83
Is that an air cooled Onan?
I'm looking at a 30kw liquid cooled Onan or Kohler. I think the GM 3.0L in line 4-cylinder engine running at 1800-rpm in the Onan will be more reliable and quieter than the GM 1.6L 4-cylinder (timing belt) running 3600-rpm in the Kohler. I have two heat pumps and a total of 16kw of emergency heat strips which come on when the heat pumps go into the defrost cycle.
I own a Generac RV generator in my RV, and from that experience, don't want another Generac product.
Bill
/ Whole house generator #84
Well I hate to dog Generac but I sure took a beating on mine. The service technican said for some odd reason a winding on the stator must have just come loose. Anyway, that is history.
My 20KW Cummins/Onan is air cooled. I would love to have a water cooled unit but they are twice the price. I actually think the water cooled has similar sound levels as this air cooled unit. You can stand right beside this one and carry on a conversation without a problem. It just purrs. Nothing like the 15K I had.
When testing this Cummins/Onan after I installed it I loaded it up nicely and went inside with my garage door still up and went to my bedroom which is next to the generator. With the air condition on in the house I had to listen to hear if this generator was running. Before, I had to close the garage, the bathroom door, the window in the bathroom and a closet door. Then I could stand to sleep if I didn't pay much attention to the noise. BIG difference.
/ Whole house generator #85
I've had good luck with the Generac air cooled units so far. I have a 7kw (4 years old) at my house and have installed a handful of others. None have had any problems, but none of them have more than a few hundred hours on them either.
/ Whole house generator #86
I think, each individual has to make a choice on quality of a generator, depending on their use and dependence.
While I finally bought a generator, I don't expect to use it more than a few times, for the house. Even at that, it would be for the "essentials". I kind of lean toward the "throw away" models. If I have occasion to use it elsewhere, that's fine. I don't really consider the Generac, which I bought, "throw away". ... Kind of in between.
For those, who can't live without power, or they lose power frequently, they might be better off with a more expensive, better unit.
For my "intended needs" and power outage experiences, I can't justify a $2K/plus generator.
/ Whole house generator #87
Just found out that in Oregon, a propane standby generator has to be at least 10 ft. from the pressure regulator. Won't fit where I had planned, so that makes the decision for me--an 8.5KV portable gasoline unit.
/ Whole house generator #88
Since most of the people on this site own tractors I am surprised that more of you don't have PTO generators. Why have an expensive genset when a PTO driven unit is much less expensive. I am looking at purchasing a 45KW unit so that I can run the entire house (2 geothermal heat pumps, 220v water well, lights, TV's, 3 refrig, 2 freezers, and our PC's. I was told I should have no problem running it with my JD 5105 (105hp) diesel. If I do I will borrow my Brother in Law's JD 4450. We have plenty of diesel stored on the farm.
/ Whole house generator #89
For those who have 1 tractor, they lose its use while running the genny. For me, the generator requires more PTO horsepower than I have.
/ Whole house generator #90
I prsonally usually lose power in winter...under snow. I need the tractor to move snow.
/ Whole house generator #91
I look at it the other way. First, if there's a storm and the power is out I'll likely need my tractor for something other than producing power. Second, why put a lot of hours on an expensive tractor when you could put them on a much cheaper generator? Third, my tractor is a lot louder than my generator, especially at the higher RPM's needed to run a PTO generator.
/ Whole house generator #92
I'm away from home some of the time and there are other times when we are both away from home for a period of time. It would impossible for my wife to hookup the tractor and generator by herself, and when we were both gone, it wouldn't work automatically or by remote control.
We have two high efficiency heat pumps with digital controls that would be sensitive to variances in voltage and harmonic distortion along with computers, a microwave oven, front load washer/dryer, dishwasher, TV/DVR, and electric range controls. Tractor driven PTO generators are not known for clean, steady, low harmonic distortion AC power.
Bill
/ Whole house generator #93
Bill
Neither are box store portables or low end 3600rpm (Generac) standby units. My limited experience with pto vs box store is the pto maintains frequency better than a box store portable unit. Didn't have a scope for harmonics, but I have a hard time believing there is much difference in AC noise.
/ Whole house generator #94
I think you will find that most newer generators regulate the voltage electronically now instead of a manuel governor. Sooo they are very accurate,,
/ Whole house generator #95
Same here. Or, it's after a terrible storm or tornado and I need the tractor for other things. It would actually be very rare for me to need generator power for my home for an extended period of time and not need my tractor. I'm glad some people can find such a setup useful. I'm sure it is less expensive. However, I'm very pleased having a completely self contained Yanmar diesel powered 65,000kW generator with a 400 amp service rated automatic transfer switch. I basically opted to spend a little more money and have more convenience and the use of my tractor. Well, it was actually quite a bit more for that size generator. My 400 amp service rated automatic transfer switch alone cost more than what most people have quoted for their entire "whole house" system.
It seems like when we have a really bad snow storm I almost always end up breaking a blade or something by finding man hole covers that I was never told were there etc. It's nice to be able to run my shop as normal using welders, plasma cutters, air compressors etc. during those times. Before, if I broke something and we had a really wide power outage, I was pretty well out of luck if I broke something. My little portable 8500kW Honda generator was great for keeping the furnaces running, refrigerators running and a few lights, but I sort of like having my A/C in the summer too. I'm too old and spoiled to sleep if it's over 100 degrees in the bedroom.
/ Whole house generator #96
85K geny..... what do you have, your own grow room to kep lit up hehe:laughing: :laughing: :laughing:
/ Whole house generator #97
Nah, only 65k. Hey, I gotta pay the bills somehow :laughing: Just kidding, obviously. Still, I had two months in a row this summer during our really, really hot spell when my utility bill was 4 digits. :mad: Just a big family and big house, guest house and barns. I gotta feeling if we have another ice storm where the power is out for weeks at a time I'll have a huge family for a while!
/ Whole house generator #98
Tractors have mechanical governors that don't respond quickly to load changes on the generator which cause voltage spikes. Voltage spikes are hard on the microprocessors in the newer appliances and HVAC systems as is harmonic distortion.
Yep, there probably is not much difference in the harmonic distortion between tractor PTO generators, some of the box store portables, and lower priced 3600-rpm standby generators. I imagine the Chinese built "knock off" portable generators are probably the worst offenders.
Bill
/ Whole house generator #99
I believe the performance of the governor depends on the tractor. I found the governor in my newer tractor maintains rpm very accurately. I don't have experience with older, vintage tractors but I would not be surprised if the governors are not as responsive. I also suspect the greater inertia of the power train in the tractor helps to stabilize frequency with large load changes. My experience with inexpensive box store units is the limited inertia results in a drop and surge in frequency during heavy load start. I believe the governors on most box store portable units are mechanical as well, although it has been a number of years since I have had a portable stand alone unit.
During Irene, I had several neighbors with new box store units. These units would surge and hunt to maintain rpm, mostly at light load. They seemed to be stable when given a load, but when lightly loaded I could hear the engines surge and cycle. (Gets rather annoying late at night). In contrast, the tractor RPM stays very stable, regardless of light or heavy load. No cycling or hunting. Set the engine speed to PTO rpm, verify frequency, and it will stay at that speed for hours without varying.
Voltage seems to be pretty well controlled with the newer electronic AVR (automatic voltage regulation) units, even with small changes in speed. The capacitor based voltage regulation is not quite a responsive, but AVR seems to be pretty good at maintaining voltage with changing load. At least what I could see with my Fluke meter.
/ Whole house generator #100
65KW, did you buy it used or surplus from a business? I had a buddy whom made a real deal on one from a hospital that was upgrading. He bought the whole rig with the switch for chump change.. It is Cummins powered, so very reliable .
