why so few of the (larger) 1600/1700 tractors talked about on here?
   / why so few of the (larger) 1600/1700 tractors talked about on here?
I hear ya about finding 1600 series tractors. Seems like everyone had the same idea we had: buy one before they're all gone. As it was, I think I was fortunate to get my hands on this 1643 last November.
As far as your specific question about power, I don't know if the '52s can be tuned up, but then again, the '55s and '60s are the exact same engine, so it must be possible. BTW, I run into the same problem with my tractor not having the power to do much other than travel (unloaded) in high range. That's about all it's good for.
Yeah, I can groom with the rake in High, and I can do a little snow plowing with it if it's not too deep. More power! Lol
   / why so few of the (larger) 1600/1700 tractors talked about on here? #32
I have been looking daily for posts about our tractors, I think the number of 16 and 17 series tractor owners are much smaller than that of other brands. It is always funny to read the Hydro vs. Power shuttle debate, I just can't jump in that discussion with a Dyna-QPS.
Can you explain the Dyna-QPS operation in more detail?
   / why so few of the (larger) 1600/1700 tractors talked about on here? #34
It is very similar to a power shuttle, foreward to reverse is with a lever on the dash, clutching optional. It has 3 ranges with 4 speeds in each range that are selected using a push button on the shift lever that can be switched on the fly. I have heard it described as a Hydro with a clutch interupter. I believe that the Dyna-QPS was discontinued with the 17 series tractors.
Ok .. so let's say you're in gear 5 and you want to stop. Do you still have to clutch and brake, or can you simply let off the throttle like with a hydro?
   / why so few of the (larger) 1600/1700 tractors talked about on here? #36
You have to either cluth and brake or take the shuttle out of foreward.
Ah ok ... I'd love the power of the 1660, but I really don't think the trans would work for me. I constructed about 6000 sqft of driveway the other day for a guy. Dug out the grass and dirt to about 4" below, added 40 yards of gravel. I did so much loader work and "back & forth" motions that I can't imagine having to use my left hand for anything other than steering (right hand was on the loader joystick practically fir 6hrs straight)
   / why so few of the (larger) 1600/1700 tractors talked about on here? #38
The Dyna QPS is a standard power shuttle transmission in terms of forward/declutch/reverse operation. All direction changes can be made with the shuttle lever and without using the foot clutch. Shifting gears inside each of the 3 ranges is done by pressing a button on the shifter, which briefly disengages the clutch, shifts the gears, and then reengages the clutch moving to the next gear. It does not work like a true powershift in a larger tractor where you can be running at full throttle with a heavy load or ground engaging implement and shift gears without slowing down at all. With the QPS if you are pulling it will almost come to a stop between gears while it shifts.
3 Row Twin Row Renaldo Planter (A53317)
3 Row Twin Row...
yellow ball Trailer (A56859)
yellow ball...
Generator (A56857)
Generator (A56857)
2000 INTERNATIONAL 4700 (A58214)
2000 INTERNATIONAL...
WHIRLPOOL DRYER (A54757)
WHIRLPOOL DRYER...
UNUSED JCT 72" HYD 4N1 BUCKET (A52706)
UNUSED JCT 72" HYD...
