Wide Load Extended mirror suggestions?
   / Wide Load Extended mirror suggestions? #1
blueriver
Super Member
S.E.Oklahoma
JD 5520 Montana 4340 Farmall Super A Montana 5720C
I may be loading a portable 12' x 30' x 8' building on skids onto a 34' GN and hauling it ... I know I need the wide load permits ... what I'm trying to find are mirrors to extend the current mirrors on the Dodge 3500 Dually.
Anyone got any recomendations ...
   / Wide Load Extended mirror suggestions? #2
For a one time trip, I would:
1. Hit up a junkyard for the mirrors you want from a semi
2. Put a roofrack on the truck as far foward as possible
3. Mount a 14' 2x4 or a piece of 2x2x3/16 angle to it
4. Mount your mirrors to the 2x4 or angle
Edit: for more than one trip, I would look into someting like: Mirrorbar or: 14" Extendable Mirror Bars, Oversize Load, SSTUBED
The 2nd link looks like you could make one fairly easily...
Aaron Z
Thanks ... That second picture looks like all one would need is square tube that will slide into another square tube and you could adjust them any width using a set screw ... mount the mirrors on the end.
I also like the roof rack idea as well if one could find just the front rail of the roof rack and mount to that.
Thanks again.
   / Wide Load Extended mirror suggestions? #4
Awe man, we definitely will need pics of that load!
   / Wide Load Extended mirror suggestions? #5
Looks like you could make some if you have any kind of mechanical skills. Sounds like a fun project and heres a picture I found...
   / Wide Load Extended mirror suggestions? #6
What about a set of OEM towing mirrors?
   / Wide Load Extended mirror suggestions? #8
I had some extended mirrors on a chevy I use to own. They were plastic and slipped over the factory mirrors. It was an extra adjustable mirror set outside the factory ones. I could see around an 8' wide horse trailer. You might be able to adjust them enough for 12'. I can't remember the name, I will try to find it.
   / Wide Load Extended mirror suggestions? #9
12' wide 38' long with stock mirrors
   / Wide Load Extended mirror suggestions? #10
I pull a 12'5" boat, 13' total width on the 38' trailer, with no issues just using a couple of chase vehicles, spotters when backing up, and just the factory mirrors on my 06 F-350.
I really dont think you need to bother for just a one time trip.
Chris
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
2019 CATERPILLAR 259D3 SKID STEER (A60429)
2019 CATERPILLAR...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2017 Kubota M7-151 Premium MFWD Tractor (A56438)
2017 Kubota M7-151...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
