Wide Load Extended mirror suggestions?
   / Wide Load Extended mirror suggestions? #1
blueriver
Super Member
S.E.Oklahoma
JD 5520 Montana 4340 Farmall Super A Montana 5720C
I may be loading a portable 12' x 30' x 8' building on skids onto a 34' GN and hauling it ... I know I need the wide load permits ... what I'm trying to find are mirrors to extend the current mirrors on the Dodge 3500 Dually.
Anyone got any recomendations ...
   / Wide Load Extended mirror suggestions? #2
For a one time trip, I would:
1. Hit up a junkyard for the mirrors you want from a semi
2. Put a roofrack on the truck as far foward as possible
3. Mount a 14' 2x4 or a piece of 2x2x3/16 angle to it
4. Mount your mirrors to the 2x4 or angle
Edit: for more than one trip, I would look into someting like: Mirrorbar or: 14" Extendable Mirror Bars, Oversize Load, SSTUBED
The 2nd link looks like you could make one fairly easily...
Aaron Z
Thanks ... That second picture looks like all one would need is square tube that will slide into another square tube and you could adjust them any width using a set screw ... mount the mirrors on the end.
I also like the roof rack idea as well if one could find just the front rail of the roof rack and mount to that.
Thanks again.
   / Wide Load Extended mirror suggestions? #4
Awe man, we definitely will need pics of that load!
   / Wide Load Extended mirror suggestions? #5
Looks like you could make some if you have any kind of mechanical skills. Sounds like a fun project and heres a picture I found...
   / Wide Load Extended mirror suggestions? #6
What about a set of OEM towing mirrors?
   / Wide Load Extended mirror suggestions? #8
I had some extended mirrors on a chevy I use to own. They were plastic and slipped over the factory mirrors. It was an extra adjustable mirror set outside the factory ones. I could see around an 8' wide horse trailer. You might be able to adjust them enough for 12'. I can't remember the name, I will try to find it.
   / Wide Load Extended mirror suggestions? #9
12' wide 38' long with stock mirrors
   / Wide Load Extended mirror suggestions? #10
I pull a 12'5" boat, 13' total width on the 38' trailer, with no issues just using a couple of chase vehicles, spotters when backing up, and just the factory mirrors on my 06 F-350.
I really dont think you need to bother for just a one time trip.
Chris
Chris
Thanks Chris ... about a 5 hr trip and darn well need to see whats going on behind me. I've been searching the wide load regulations for Oklahoma and Missiouri Just in case this comes together.
   / Wide Load Extended mirror suggestions? #13
over years i have seen a good amount of "replacement mirrors" that can be adjusted in/out with some set screws. problem is, the further those mirrors hang out, and the larger / heavier mirror you go with. larger chance if you hit a good wind or bump, you may tear up the door paneling that goes around the mirror connections, as the mirror begins to bounce and possibly fall off. but more likely begins sagging down.
not sure if it would count for laws, but video backup system. granted you will not be able to see down the sides of what ever you are hauling *shrugs*
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2021 XCMG CV123PDU ROLLER (A60429)
2021 XCMG CV123PDU...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2020 FREIGHTLINER...
1991 International 4900 Box Truck (A55315)
1991 International...
Schulte SBW800 Rock Windrower (A56438)
Schulte SBW800...
2014 Nissan Juke SUV (A59231)
2014 Nissan Juke...
