Wife Destroyed Brand New S240 Sport -- What to Do?
Status
Not open for further replies.
   / Wife Destroyed Brand New S240 Sport -- What to Do? #11
If I was your spouse, I'd be ticked that you bought such a fragile piece of equipment. :laughing:
bout fell out my chair when I read this...
I have been thinking about the roots our mowers keep under control but have Deere Dude has mention have used an axe on many over the years. But my wife is as good on mower as I am.
Without seeing the deck this may not work but can you not take the spindle off, take a reasonable thick piece of flat metal with holes drilled through it and the deck, using decent size bolts (at least 1/2") pull the deck back flat enough to be fine? If you leave any metal on that deck to support it as it is weaken be sure the bolts clear the blades and the belt and spindle pulley.
   / Wife Destroyed Brand New S240 Sport -- What to Do? #12
Replace the deck and move on. You'll have a good parts deck. Don't feel so bad I hit a hidden rock and bent a 250 baffle to h!ll lol. Accidents happen. I'm going to repair the baffle for now and replace at the end of the mowing season. Seriously though if you can't fix the deck, replace it. It's cheaper than a new tractor. The only abuse the tractor took was the deck. Check over the linkages that raise and lower and make sure all is ok.
   / Wife Destroyed Brand New S240 Sport -- What to Do? #13
Your being too hard on the Missus. Get her a nice Riding Push mower. Here's two samples that are pretty fool -proof...
   / Wife Destroyed Brand New S240 Sport -- What to Do? #14
My kids would love that bicycle mower... right up until I actually wanted them to mow the yard with it.
   / Wife Destroyed Brand New S240 Sport -- What to Do? #15
Do you enjoy arguing with your wife? :confused:
Smile, buy a new deck, and assure her you will "take care of" those roots. Be happy no one got hurt! :dance1:
   / Wife Destroyed Brand New S240 Sport -- What to Do? #16
Me, I would be out there trying to repair it. It doesn't sound that difficult. I would not blame the wife. Stuff happens, and I have broken things while mowing too.
   / Wife Destroyed Brand New S240 Sport -- What to Do? #17
Just came in from repairing my brand new deck myself. All I did was cut off the bent part of the baffle with a grinding wheel, and it looks pretty good. While at it I washed it up, pulled out the manual and hit all the grease points. My point is just like the others, try and fix it, if it's beyond that, replace the deck. I'm sure your wife got pretty shook up and had no intentions of wiping out the deck. Things can happen quickly and injuries too, I'm glad you didn't report she got hurt by fly metal and bits . Things happen, it'll be fixed and you'll look back and chuckle.
   / Wife Destroyed Brand New S240 Sport -- What to Do? #19
I assure you it was the dog's fault. When I backed my truck into my daughter's truck, at first it was her fault, then my wife's fault. But ultimately I determined it was the dog's fault.
Regarding your mower, straighten the deck out then the spindle will be aligned. I did something similar to a snow blower getting a chunk of wood buried in the snow caught in it. It bent the box into which the auger bearings are mounted. After taking it apart, then straightening the box it worked fine.
   / Wife Destroyed Brand New S240 Sport -- What to Do? #20
Just straighten the deck with hammer/tools and move on with your life. I am sure the rest of the tractor is fine. This is one of Deere's economy models, and it's not worth getting bent out of shape over this (no pun intended).
I hit a stump with my old LT150, and had to straighten the deck and replace a spindle (which only came in pairs, so they both got replaced). Used the tractor another 5 years after that before the deck began rusting out, and then replaced with an X380.
Status
2025 K2030 UNUSED Metal Garage (A53117)
2025 K2030 UNUSED...
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
2015 CATERPILLAR 262D SKID STEER (A51246)
2015 CATERPILLAR...
2016 Ford F-450 Ext. Cab 4x4 10FT Flatbed Truck (A51691)
2016 Ford F-450...
45051 (A51694)
45051 (A51694)
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
