Wildcat 84” grapple any good?
   / Wildcat 84” grapple any good?
Somethin’s up. I just found another one at a local equipment jockey. It has serrated teeth on the radius and some labeling.
This guy at JM is usually about as affordable as it gets, but he’s $400 more than the other one.
   / Wildcat 84” grapple any good? #12
Wait, I see differences. Look at the curvature of the lower tines.
The radius is smooth on the one for sale. The radius on the Wildkat brochure shows serrated radius.
I see some other subtle differences, too.
Maybe these are irrelevant or just slight design changes???
Probably just design changes. I noticed that the 'Granite Grapple' for sale here by a vendor is a little different than the one I have.
   / Wildcat 84” grapple any good? #13
Have you looked at MTL grapples? That is what I have on my skid steer and it is very well made and heavy.
   / Wildcat 84” grapple any good? #14
My grapple is - SGC1560 @ 820 pounds. The larger one - SGC1584 is listed as - 1030 pounds. And, yes, - Land Pride has gone the way of several others - they have a myriad of different grapple styles.
Lets face it - teeth here/teeth there - makes next to no difference in how the grapple will function. And has been previously mentioned - could be a simple change in design.
However - I had a thought. The Wildcat you found at the local JM dealer is $400 more than the one listed on FBM. Could that difference be - shipping costs.
   / Wildcat 84” grapple any good? #15
Don't buy without inspecting in person. Look at all the welds. Make sure everything is fully welded and gusseted.
If you are planning to push trees over that long fork design will be a PITA for you to fix when they bend splay apart.
Heavy implements made from thick mild is a waste IMHO.
   / Wildcat 84” grapple any good? #16
That's the way I've always done it also - mikester. I've only been burned once. Not because of the quality of the steel or the construction. I didn't realize that a light duty disk harrow simply would not cut my ground.
The major reasons I bought the Land Pride - SGC1560 - short, heavy forks, well gusseted and made of AR400 steel.
It follows the old saying - Buy once - cry once. I bought the grapple & WR Long setup ten years ago. It's saved my back and legs countless times.
   / Wildcat 84” grapple any good? #17
That's pretty cheap. I paid about that for my 84" grapple over 25 years ago!
Lofflin brand out of NC. Dual "lids" and flat bottom which I'd recommend. I have "tweaked" the lids in this time but this was doing things that I shouldn't have. It's still fully operational.
Agree. I hate buying something you have to “be careful with” all of the time.
I’m not going to push trees over, just pick up large wads of brush, sticks & small logs.
The more I look into these grapples, the bigger the headache gets…..
I believe in buy once, cry once, too.
I might give Messicks a call and see if they have the Landpride in an 84”.
I bet it’s $4,000
   / Wildcat 84” grapple any good? #20
Here's what heavy 1/2" mild steel tines, poorly welded to 1/4" mild steel tube with unsatisfactory gussets looks like. I know it's 1/4" thick tubing because the grapple lid cylinder mounts tore a hole in the tube. I also discovered that the thick black paint concealed a 1/8" thick galvanized fence post tube holding the top lid together. That lid broke in half due to fatigue trying to grapple root balls.
This is why I ended up fabbing my own grapple using AR400 and twin lids. I found the single lid was ok for handling telephone pole like logs but struggled with everything else.
I also prefer the long bottom grapples now - if you have the loader capacity you can grab and carry more brush/logs etc. Could never hold more than a few logs on the old grapple.
2015 Ford Explorer AWD SUV (A44572)
2015 Ford Explorer...
2016 Ford Explorer AWD SUV (A44572)
2016 Ford Explorer...
2006 Club Car Villager 8-Seater Electric Transport Vehicle (A44572)
2006 Club Car...
2020 Toyota Tundra Pickup Truck, VIN # 5TFEY5F14LX266984 (A44391)
2020 Toyota Tundra...
2023 FORD TRANSIT T250 CARGO VAN (A43004)
2023 FORD TRANSIT...
2005 GREAT DANE REEFER (A43004)
2005 GREAT DANE...
