Will a Hydraulic pump pump water ?
   / Will a Hydraulic pump pump water ? #1
FredH
Platinum Member
Ruch , Oregon
N.H. TC-30
Just a curious question , Not planning on trying or doing . As the title says , Would a Hydraulic pump , like on a wood splitter , pump water in a open system ?
Open system meaning a resevoir to draw from but pumping out a different way , not back into resevoir .
Have no idea " Why " this got stuck into my brain , But google researching did not produce much other than the link below mentions a water based fluid that
a pump can be derated in rpm's thus decreasing pressure in the " Fluid type and Viscosity " section .
The Right Pump for the Job
Fred H.
   / Will a Hydraulic pump pump water ? #3
I'd say it will briefly. Then it'll either seize up from no lubricant or rust up.
Figured it would for a bit anyway , since that link mentions the requirements for different seal types with different fluids . The bigger question is WHY this was even in my brain to begin with ???????????? Have no idea were it came from , woke up this morning with this question rattling around the vast emptiness of my head :confused3:
Thank's :thumbsup:
Fred H.
   / Will a Hydraulic pump pump water ? #5
We have some hyd pumps at work and have been told in the event of a catastrophic fluid loss water could be used....it'll work until it doesn't if that makes sense. These operate at 10,500 psi and would be considered life safety.
   / Will a Hydraulic pump pump water ? #6
What are they for?
   / Will a Hydraulic pump pump water ? #7
What are they for?
Hydraulic extrication tools. Think jaws of life. Trade name TNT tool was the company that made that claim
Brett
   / Will a Hydraulic pump pump water ? #8
Brett
A gear pump is not ideal for water, but there are many "water based" hydraulic systems. There are usually some soluble oils added for lubrication.
One limit for pressure systems would be cavitation, and subsequent erosion of metal parts. For "open systems of fluid transfer, as long as there is some fluid to limit metal wear, water pumps by positive displacement as well as it does by inertia.
Don't expect long service life from an unadapted hydraulic gear pump though,
   / Will a Hydraulic pump pump water ? #9
Especially at 10,500 psi. Said it'll work but I would fully expect it to trash the pump pretty quick. Like I said it'll work till it won't. Then it'll be done
Brett
   / Will a Hydraulic pump pump water ? #10
One would not expect such high pressures in an "open" fluid transfer application.
Pressure drop as a fucntion of line footage would be "pumping to the moon". ;-)
UNUSED Yellow Outdoor Patio Fabric Screen (A53117)
UNUSED Yellow...
Utility Trailer (A52377)
Utility Trailer...
Case 1020 25ft Draper Head (A55301)
Case 1020 25ft...
2014 10ft T/A Dump Trailer (A51691)
2014 10ft T/A Dump...
2008 Ford Ambulance (A47477)
2008 Ford...
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
