RonMar
Elite Member
ray66v said:Guys! COME ON! You match the speed of the wind + enough speed to come down to the runway then you reduce power and you fly it down to the runway eventually matching the speed of the wild and touch down on the runway. You don't have to stall it, you don't have to land it nose high. You land it flat as a result of slowly flying down to the ground. Then you hold the controls exactly the way they were on the decent and as long as you have enough fuel you could sit there, (stationary), all day. NO BIG DEAL. How can you have trouble keeping your speed down with a 100 mph head wind! A head wind slows the plane down. A 100 mph head wind slows the plane down 100 mph. If it will fly at 50 mph, and you have a 100 mph head wind, you can be flying so slow your going backwards along the ground. If the wind is 100 mph and your air speed is 100 mph you are flying stationary (hovering). Fly the approach at 101 mph and your ground speed is 1 mph. Yes you CAN land any airplane FLAT and not harm it if you are a good pilot. Most students land flat half the time, (by accident).
Yes, you will have to leave the power at that final setting, or go backwards down the runway. Yes you are not going to be able to taxi anywhere but into the wind. The question was WILL IT LAND. The answer is YES, but, I guess I might be the only one here that should land into a strong headwind.
FYI: There are guys out there that actually have landed into gusting winds 1/2 that speed. I know one that did do it in a 150.
The problem is not that simple. You could approach as you described, but with enough power on to have 0 ground speed in a 100 MPH headwind(aircraft flying at 100 MPH airspeed), the aircraft nosewheel would touch first. As soon as the mains try and touch down, the increase in wing angle of attack as the fuselage pitches up, and the resultant increase in lift would cause the plane to lift off again(and slow down). And of course anyone who has had any training in a C-150, knows that you are beaten severely about the head and shoulders by the flight instructor for abusing the nose wheel with excessive nose down pitch attitude. It is the weak link in the landing gear and therfore it is always the first off and the last to touch down.
You don't have to lift the nose wheel off the ground in a C-150 to takeoff. Your takeoff run is long, and the wheel speed is high, but full power down the runway and eventually all 3 will come off together.
If the wing is not stalled it is what?... flying. If the wing is flying, the airplane is flying. You could touch down, but you couldn't stay down(land) on the gear
