will it take off?
   / will it take off? #711
da Teacha, It was an "err on the side of safety" thing, a disclaimer like on MYTH BUSTERS, don't try this at home kids. If you blow yourself up, I'm in the clear.
A glass of super heated water is a danger in a microwave because it might turn to steam at any given moment, say just after you open the door. Even just a few oz of water turning to steam all at once is not good to be close to and if only half turns to steam the other half is sprayed out in 4 pi steradians, a scalding danger.
That little window in your oven is supposed to be transparent to microwaves. The emissions of microwave energy is right behind the window. If the oven cavity provides a poorly matched load to the output cirsuits you get a high VSWR which can result in pretty high voltages at microwave freqs. This is most likely what caused the arcing at the window. The material has been partially carbonized (black burn markis) and is not so transparent to microwaves now. When you put your "not really good to use in microwave" dishes in there with not enough food to take up the energy, you may get additional arcing and degradation of the little window. You could replace the window with a microwage transparent cover. If you operate the oven with the little window removed, then spatter, steam, and debris will likely get in where it shouldn't.
If you retire the oven while it still has a good power supply you have the makings of a good welder if yo want a fun DIY project.
Pat
   / will it take off? #712
The amt of water that turns to steam is miniscule due to the extreme quantity of heat that the overheated water must give up to the portion that changes state in order to finance the change. The amount that can change [in grams] is: (y)(sample mass)/540. Y=sampleT-100C, at sea level. I doubt that even extremely pure unpressurized water will go above 105C without boiling unless pains are taken to keep it absolutely still. That means a pint sample would only be able to elevate less than 1/5 ounce to steam energy. A high expansion ratio tho - enuf to blow around a lot of hot water.
Larry
   / will it take off? #713
SPYDY, How much boiling water blasted into your face does it take before it is an unwelcome event? I don't wish to pull along side and compare dorsal fin heights or quibble over explosive forces but your prognostications may underestimate the effect:
In the popular Discovery Channel show Mythbusters, an experiment was conducted where distilled water was placed in a microwave oven for several minutes long enough to boil, but no convection (boiling bubbles) took place. When a contaminant (a sugar cube) was added to the superheated water, it had an explosive effect. However, this effect also occurs with normal tap water, as macroscopic impurities (especially those which carry air bubbles) are needed for boiling to start. The dissolved impurities in tap water are not enough to inhibit the superheating.
Of course the MB bunch only demonstrated one sceanario of many possible.
For me, the risk is great enough to indicate caution. Your mileage may vary and your burn and trauma unit may be a shorter drive.
Pat
   / will it take off? #714
Pat, I have successfuly resisted not answering. In actuality, the objective physics stated in my post covers all that you have brought up. I suppose that there is a danger of remaining objective with some,-Idontthinkyou-, in that it may be missed that it takes very little explosive energy to throw a liquid a small distance. The properties of this liquid promote its intimacy with the skin. Add to this factor its T and its high specific heat and you have a problem. You are not going to be burned any worse by the subjectivity of the surprise. Indeed the tendency of the water to spray in the explosive case, rather than travel en mass as if thrown, will dilute the effect, and result in a more pleasant burn. I dont need to try this at home. I just know it. The need for nucleation sites to catalyze change of state reactions is also a real concept to me. Things just have to start somewhere!
Larry
   / will it take off? #715
I'm wondering at what point a burn becomes "more pleasant"!
I took the kids on field trip to a coal fired power plant once a few years ago. The tour guide made a pretty big impression by explaining to them that a jet of dry steam at about 1500 degrees coming from a pinhole leak in one of their steam lines would make a very nice tool to remove fingers from your hand without leaving any blood behind since it would cauterize the wound as it cut the fingers off.
As for welders, Pat, I'll just stick with my Lincoln TM500-500. It weighs 750 lb, will run on 220, 440, and maybe 880 v. It has a 60% duty cycle at 500 amps, so I could basically burn through 1/4 rod as fast as I could load it all day long and not stress the thing. It works as a crude plasma cutter by simply turning it up a bit from the normal 100 +/- amps I use and running small diameter rod. The best thing about it is that it was free. :)
   / will it take off? #716
SPYDY, OK.
daTeacha, Terrific welder at an even better price. I envy your good fortune. However, for some of us there is a perceived value in not having to rent a crane to move a welder or risk a hernia or worse trying to move it. My welders are way less powerful. I have a wire feed Lincoln "Lunchbox" that is made to handle shielding gas but I only use flux cored wire. I also have a Lincoln "Tombstone" ac/dc/dc reverse stick welder that is heavy enough that I put it on a hand truck type carrier. I sometimes wish I had a more powerful MIG but my little 120VAC unit does over 90% of what I need and the stick will handle the rest. It is handy since you can always find a 120VAC outlet.
I did splurge a bit on my plasma cutter. I went with a Hypertherm 20-40 amp unit and I really like it. I am nearly useless with an O-A cutting torch but can do pretty credible stuff with the plasma rig.
There are some real neat DIY welders that can be done from microwave power supplies. Maybe one of your "little geniuses" would enjoy a project like that. There are refs on the net.
I too was somewhat puzzled by a consideration for varying degrees of pleasantness of scaldings. I guess it would be a simple LESS IS BETTER thing. If all things are relative then being scalded less is better and by extension more pleasant.
You can turn up the heat for me if you want. We have had an arctic draft blow down here and give us an ice storm. One day it was in the 60's and the next it is an ice storm and in the 20's with everything ice coated. The countryside is beautiful but the roads are nearly 100% ice coated. I don't mind driving on ice when there is very little traffic because the danger isn't what my equipment or I will do but what others may do to me.
Pat
   / will it take off? #717
Hey Pat.... I would made you a deal... I woulda kept the cold air up here is you keot the moisture down there.... we got sleet not ice where I am at so the roads are really just snowpacked.
   / will it take off? #718
I just couldn't pass up the welder at the price, especially since I didn't have one at the time. The portability issue just hasn't come up -- I do my welding in the shop or just outside the door. Field repairs are a non-issue so far. It's an old fashioned stick welder, no wire feed, no gas, etc. It was originally used in a Terex plant near where my BIL lives, with about 6 guys using one machine to assemble earth movers, running a common ground strap and each guy with his own stinger. Yeah, it's a bit much for what I do, but again, at the price I can't complain too much.
   / will it take off? #719
rback33 said:
Hey Pat.... we got sleet not ice where I am at so the roads are really just snowpacked.
I took the Prius into OKC for our free oil change/tire rotation (Free changes as long as we own it.) For variety I went up to Shawnee and took I-40 which was essentially completely clear. In one area west bound traffic got congested and at one point slowed to 15 for a couple hundred yards. There was an 18 wheeler on the shoulder facing the wrong way, and a HP on scene. A little later there was a 10 wheel dump truck (looked to be full of sand) upside down in the median. except fot that, traffic was 70+ but most businesses had ice rinks for parking. Ice rinks with gently rolling hills and grades. I went to one of the Scottish places for lunch (Mc D for a chicken sandwich) and when I was leaving there were a few cars parked "nose in" to the curb on a slight slope who couldn't back out. One guy in a pickup was especially fun to watch, must have hit 80-90 MPH on his speedo following the concept that if you press the accelerator and it doesn't go good enough to suit you then press it more. The Prius backed out just fine from immediately uphill of the truck and I got out of there before BAD things happened.
Coming home the other day froma trip to pick up iron materials for a project the secondary highways near Konawa were all ice. I was a tad late getting hoime and my wife was worried. I was late because I stopped to pull folks oiut of the ditch. One of the scenes was particularly entertaining.
A couple in a SUV were being pushed by hand by 4 guys who stopped to help. They were straining to push the SUV INTO THE DITCH! Their thought was they woiuld build up speed on the downhill and then the driver would make it back up to the road. Afterall they colidn't push it back up on the road so it was supposedly better than no plan at all. I just sat and watched for a few seconds and then rolled my window down and asked if they wanted the SUV in the ditch or on the road. They explained the plan (I kept from laughing and shot a 180 in prep for using my 12,000 winch on the front of the 1 ton Dodge-Cummins. Winch was totally ice encrusted and woild have been a hassle to use, possible but a hassle. I grabbed a couple HD racheting cargo straps and they hooked me up and I backed slowly and put the SUV back on the road. I didn't ask why with 4X4 they couldn't just ease it out.
Although driving on ice is more dangerous I have the requisite skills and I know my equipment. What I can't control is the other folks out there who go 30MPH right up to a stop and then slide through the intersection at 30MPH, maybe dong a 180 or 360 on the way if one of the tires caught a bit of traction hitting a dry patch. I have banked turns in my driveway. If you break traction while going too slow you could slide off the drive and go down the hill. If you go too fast and break traction you could go off the drive and go right into the adjacent pond. Within the band of allowable speeds there is no problem.
So far my closest call was coming to the garage too fast. You have to make a 135 degree turn while starting down a mild slope to the bottom of the apron and then up hill slightly on the apron into the garage. IT was glaze ice with a film of water on top (very slippery) and I was in a nice 4 wheel drift with slight braking. If I used more brakes it opened up my turn and made me head for the location where I really didn't want an impromptu door. I had to ease in a little throttle so I could steer the front wheels better (4X4 Dakota) and got the front headed throgh the garage door but at a 10-15 degree angle. I delayed turning the wheel as long as I could considering the JUNK in the garage and then straightened it out and stopped. Luckily the floor was dry. I credit 50% skill and 50% pure dumb luck that I didn't mess anything up.
I have a new icy garage apron approach policy:
DEAD SLOW on the 135 degree turn until lined up on the entry.
Pat
   / will it take off? #720
daTeacha said:
I just couldn't pass up the welder at the price...Yeah, it's a bit much for what I do, but again, at the price I can't complain too much.
I do about 1/4 of my welding in the field using the MIG and flux cored wire. My genset handles it just fine. I had thought of getting a combo welder/genset but I don't do that much HD welding afield. What I am considering now is if I would use my plasma cutter enough in the field to warrant getting a gas powered compressor or a more powerful generator that can run the plasma and an electric compressor at the same time. A fringe benefit of the larger generator is it could be a better backup generator for the house. So far we have dodged the bullets of this ice storm and only had one brief power outage of about a second and a half.
Pat
2014 Chevrolet Express Van (A55973)
2014 Chevrolet...
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
2000 INTERNATIONAL 4900 CAR HAULER (A58018)
2000 INTERNATIONAL...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
2005 EZ-GO Utility Cart (A55853)
2005 EZ-GO Utility...
Deere 333G (A53317)
Deere 333G (A53317)
