will it take off?
/ will it take off? #1
schmism
Super Member
Peoria IL
New holland TC(33)
Sense we were having so much fun debating the finner points of tire pressure in the other thread....
i thought this would be kinda fun...
a plane is standing on a movable runway( something like a conveyor).as the plane moves the conveyor moves but in the opposite direction.the conveyor has a system that tracks the speed of the plane and matches it exactly in the opposite direction.
the question is
will the plane take off or not?
(ps its been debated to death on other forums, its always fun to see how people present the theory behind there answer)
/ will it take off? #2
Since there is no relative motion with respect to the wings and the surrounding air, there is no lift. All you do is wear out the tires!
/ will it take off? #3
Conventional aircraft, normal wing, no forward motion in relationship to the air?
It will sit there and make a lot of noise,
At least until the wind blows across the wing enough to provide lift (be a lot of wind) at which point,,,, hmmm I think it would then rapidly accelerate being "disconnected" from your treadmill.
/ will it take off? #4
I'm no aeronautical engineer, but it seems to me that what propels the airplane is the prop which is really pulling the aircraft forward through the air. The landing gear can spin as fast or slow as they want with little effect on the actual speed of the aircraft. I guess there might be some drag associated with friction on the bearings, but I would think that would be minimal. The conveyor would only have a negative affect if the airplane's forward movement where controlled by motors driving the landing/running gear.
/ will it take off? #5
I'll play along...
The plane will take off and the plane's wheels will be spinning at twice the normal speed at that point.
The conveyor (runway) is dealing with ground speed and the plane needs airspeed to take off.
/ will it take off? #6
This has been beating to death way too many times.
The plane will take off. The plane does not move by force of driven wheels (like a car). The plane uses thrust from the jets or props that propel the plane forward. Therefore, the conveyor belt can be spinning at 100mph and all that does is spin the free rolling wheels faster than the plane.
/ will it take off? #7
Darn, your right, I am visualizing the plane remaining motionless with regards to forward air speed, but that would not be the case.
/ will it take off? #8
If the plane is actually moving, that means air is moving over the wings, so yes it will lift off. Now the wheels will be moving twice as fast as normal because they will be rolling their normal speed plus the speed of the conveyer belt. The key here is the plane is moving.
Edit: Daggone, when I started typing this up. Nobody had responded and then people stopped by the desk and I actually had to work for awhile and then all of these responses.....
/ will it take off? #9
Actually, this sentance is not clear enough to draw a conclusion. It seems to imply that the speed of the conveyor belt is sufficient to keep the plane fixed in a single point in space (it says it matches the speed of the plane, not the ground speed of the landing gear tires). This is nearly impossible, but that is what is tripping people up. It would take a lot of conveyor belt speed and very inefficient wheel bearings (etc) to achieve this but the sentance is not clear enough to rule this out. If the belt were capable of doing this, then the plane would not take off. It also does not specify the type of landing gear. Some planes have skids for landing gear and/or tail wheels.:rolleyes:
/ will it take off? #10
Yes, Because there is a head wind created by the conveyor belt. Its a function of the Reynolds number and it is called ground effect.
Did I get you... cause I just made that up.
/ will it take off? #11
schmism said:
Will the plane take off or not?
Yes.
I'm in the "Airplanes are propelled by prop./jet thrust, not by wheels" camp. Seems pretty cut and dried to me.
/ will it take off? #12
I think I can say yes somewhat definitively, thanks in part to the "Reynolds number." (lol I loved that btw).... while the plane may be stationary, the conveyor and props/jet engine will eventually create enough enough airflow across the wings through their mere function to get the bird off the ground. (this next part, I am applying terms to things that are obviously theoretical... I mean look at the subject..)
I also think the "theoretical speed" being the speed the plane would be flying at if it were not for the conveyor will be MUCH higher than twice the speed of normal lift off. To create that much airflow the conveyor would be moving much faster than that. I am trying to envision what would happen after it left the ground. Would there be enough airflow to keep it airborne, or would it come right back down? Would it just hop up and down in and out of the flow?On another thought... are the engines on this plane infinitely capable of increasing the "thrust" it uses to become airborne? If so, is THIS flow the effect that causes the lift not the conveyor? If so, I don't think know how the plane would handle the dynamics as it began to fly.
/ will it take off? #13
Having spent a good amount of my life flying military aircraft the answer is it depends on the aircraft. Normal airplanes require airflow over the wing to fly. If there is no airflow it will not fly. So 99% of airplanes would not fly If they could you could simply lock the brakes and run the engine to full power and lift off with out any runway. Normal airplanes can not do this. However there are some that can. A good Platus Porter with a strong turbo and no weight inside if run to max power can be made to lift off from a dead stop. I never tried it but am pretty sure and F16 or F14 with no payload setting on a aircraft carrier if run to full power and afterburner would probably fly straight up. Assuming you could control it which you probably could not as it takes airflow over the controls to make the thing turn. Engine torque would probably spin the thing out of control. It would probably be near impossible to get one in that configuration with out breaking something.
/ will it take off? #14
Makin a lot of assumptions there, so I think we have to rule your practical knowledge of the hypothetical situation as invalid. :D Someone that KNOWS something cannot reply to this thread.:rolleyes:
You did however explain some things I had going through my head and couldn't properly convey so I guess it can stand.
/ will it take off? #15
The question is, can a plane take off from a stand still. It's possible but highly improbable. At some point the prop has to create a lift under the wings and it ain't gonna happen on a prop driven plane. Harrier jet, yeah.
/ will it take off? #16
The plane is not moving because the magical conveyer is matching the speed of the wheels in the opposite direction. If the plane does not move the plane does not fly.
/ will it take off? #17
driven
OK, now what is your explanation for this? I mean, we are defying SOOOO many physical possibilities already, what makes it IMPOSSIBLE for a prop plane of any imaginary composition to do this? Now, don't get me wrong, I don't know if there is or isn't. My degree is in biology. I just love science a whole so this discussion is fascinating to me.:D
/ will it take off? #18
I agree that the plane is NOT moving. However, the conveyor and the props or jet engines will MAKE airflow. At some (ridiculously impossible) point there WILL be enough flow to get off the ground. I just don't think it can STAY off the ground. That's my story and I'm stickin' to it. lol
/ will it take off? #20
Assuming the plane is on wheels and the wheels can spin freely at the speed of the movable runway, the plane will take off when it reaches the airspeed required for take-off. The airflow from the prop or jet or the breeze from the moving runway will never provide enough lift for take-off.
Look at it this way. There is a 1 mile long conveyor 2 feet wide 4 feet off the ground (for convenience). On the conveyor is a box. The box has wheels at each corner. A pole runs through the box and extends 3 feet to either side of the conveyor. You are on one side of the conveyor and schmism is on the other side. You both start walking at the same speed each pushing on the pole running through the box. The box will move along the conveyor. The conveyor is controlled to move in the opposite direction of the box at the same speed as the box is being pushed by you and schmism. The faster you and schmism go the faster the conveyor goes. As you pick up the speed and run pushing the box at 10 mph, the conveyor increases its speed to 10 miles per hour in the opposite direction. Will you get to the end of the 1 mile conveyor (assuming you both can run a mile at 10 mph)? Of course you will. And, in reaching the the end of the conveyor, you would have moved though the air mass surrounding you at a speed of 10 mph.The force moving the box is independent of the wheels contacting the conveyor. The wheels will be spinning at a rate equal to 20 mph during your run.
A similar condition exists with the plane. The plane is being moved by the propeller, or jet engine if you prefer, independent of the wheels contacting the movable runway. The plane will move through the air mass while the movable runway moves at the same speed in the opposite direction. At the proper airspeed (plane moving through the air mass) the plane will take off and the wheels will be very thankful because they can finally stop spinning so **** fast!
Jeff
2025 Pabreak 80in. Hydraulic Dual Cylinder 4-in-1 Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2020 CATERPILLAR 262D3 SKID STEER (A62129)
2020 CATERPILLAR...
2004 Rockwood Freedom 1640LTD 18ft. Pop Up Camper Trailer (A61569)
2004 Rockwood...
2 1/2 ft x 2 1/2 ft Metal Cage (A61166)
2 1/2 ft x 2 1/2...
Auger Bit Mini Skid Steer Attachment (A61567)
Auger Bit Mini...
UNUSED IRANCH MINI HYD THUMB (A62131)
UNUSED IRANCH MINI...
