Will mmm fit 3130 with r4 tires?
   / Will mmm fit 3130 with r4 tires? #11
My apologies, Kytractor. I seem to have posted on the wrong thread.
Hi Dannyk, your post seems to fit this thread. If not I enjoy reading them anyhow. Have you decided which tractor yet? /forums/images/graemlins/smile.gif(L3130 or L3830)
   / Will mmm fit 3130 with r4 tires? #13
My brain says 3830. My wallet says 3130! /forums/images/graemlins/confused.gif
I know the feeling, looked at bx22/7800 finally decided on L3130. Though there was a bigger jump in tractor and weight (almost double) then there was in price at that level. /forums/images/graemlins/smile.gif
   / Will mmm fit 3130 with r4 tires? #15
Kytractor - What 'bout setting up the tractor for your loader/backhoe work and buying a riding tractor for the mowing. Aren't the MMM's price in the neighborhood of a decent priced lawn tractor?? I bet you'd even get a better cut with the lawn tractor sized deck. I know your time(72" vs 48"+/- deck) is worth something too. Just a thought and I only spent .02 on it. /forums/images/graemlins/grin.gif Take it for what it's worth. Chuck
Worksmart, that is a good idea that I have thought about. Could even get one for the price of the rmm.
   / Will mmm fit 3130 with r4 tires? #17
dannyk
These tractors will do all you need to do. I think the Ag tires with the belly mower would be counterproductive. I would suggest the R4's with a 3 pt. finish mower for the yard and then you have a better tire for your other work. The shipping wt of the L3830HST shows to be 35 lbs. more than the L3130HST, but it will take larger tires and should weigh more. Hope this helps.
Lewis
   / Will mmm fit 3130 with r4 tires? #18
Kytractor
If you are mowing a yard type of turf, the finish mower would be the best and give the best results. If it is rough or has brush to clean, the field mower would be the one to use. The box blade will do the best job of moving gravel from high spots to low spots in your drive. But, if you need to pull gravel from the bar ditches back to the top of the drive, an angle blade will work best.
Lewis
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
2009 International Frazer Bilt X-514 Ambulance (A52377)
2009 International...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
AUCTION STARTS HERE @ 9AM (A52705)
AUCTION STARTS...
Adams 8 Ton Weigh Hopper (A55301)
Adams 8 Ton Weigh...
