will my bx23 haul a 5ft box scraper?
   / will my bx23 haul a 5ft box scraper? #1
escavader
western maine
bx-23 ,
As alot of you know i have the weight of my cab ,loaded tires and ag tires so i should get good traction.The dealer where im looking at a used [once ]sundown box blade[5ft] said my tractor wouldnt have a problem.Its a good looking unit,with dbl blade in back.I know most say stay with a 4fter.ANYONE ON HERE HAVE A SUNDOWN? Its priced around 700 used.Should i put a little more cash in and just by a new 4 ft?5 would be great doing roads in my atv club,if i can handle it.
Im thinking someday i might also buy another tractor,and that 4 fter might be too small then?
also A LITTLE NERVOUS about buying a not known brand,might be harder for parts in years to come [teeth etc]
Would i want one with a hinged back?
ALAN
   / will my bx23 haul a 5ft box scraper? #2
Go with a 4 footer. Once it loads up with dirt, it gets monstrously heavy. You want it wide enough to cover your wheel tracks, and not much more.
I have a 4 footer on my larger B2920, and it's the perfect size. I would not want a 5 footer.
By the way, that price sounds way too high. I got my new 4' Howse box blade for about $425 new. The 5' was only $475. The Howse has heavy gauge steel with full weld construction (ie, no bolts) and forward/reverse cutters on the back. What makes that sundown blade cost $700??
   / will my bx23 haul a 5ft box scraper? #3
I would not recommend a 5' box blade on a BX. Too light tractor, too much blade. And way too much money $700?? Look for a King Kutter, Howse etc they're well made and less expensive and will get the job done.
KK has a 4' model designed specially for the BX series of tractor, that shouldtell you something.
I have a 5' KK I pull with my CK20 HST KIOTI. My Kioti is loaded and total is more than twice your weight, with much bigger tires. In soft ground I can fill box to overflowing before I spin the wheels, half full is just right. So I know the BX isn't going to pull a 5' box.
   / will my bx23 haul a 5ft box scraper? #4
I have a Rankin 4' box blade for my BX23. When it gets loaded up, it can be real heavy. There are times that I have to engage the diff-lock just to keep it moving. I maintain my hilly driveway with it and parts are quite steep (23% grade). Doing light work might be OK with a 5" box blade, but I think you may want to stick with the smaller size.
   / will my bx23 haul a 5ft box scraper? #5
Boxblades are capable of loading up quickly and stalled even large HP tractors. I have a 6 foot on my 70HP tractor and can cause it to stop in its tracks if I hang the scarifiers on roots etc. MY 45HP with loaded tireshas all it wants with a full load of dirt and will be slipping all 4 wheels. I dont think you would be very efficient witha 5 footer and $700 is way too much for a SCUT box blade. Go with the suggestions of a Howse which is what I have and it stands up to the 70 hp without damage to anything other than a broken scarifier(s) from hanging a rock occassionally, well maybe more than occassionally.
   / will my bx23 haul a 5ft box scraper? #6
I think a 4 foot blade is plenty on the BX. I have a BX2360 with a 4 foot United from Everything Attachments. It was less than $500 delivered, and is a very good unit for the money.
   / will my bx23 haul a 5ft box scraper? #7
Concur with the majority. 4 ft will work her when loaded.
Deano
Thanks all picked up a 4 ft woods gbc48 today,will post pic soon as i get it KUBOTA ORANGE:D It was scratched a bit and was rusted on the scratches ,but still new on the pallet-last years supply .Got it for just under 500
Ikind of feel bad,cause i didnt get it from my neighbor,who is roadsalesman for the first dealer,this years moder was 150 more.It was the last hold over and i didnt want to pass on it.Guess ill only be able to use it at night:ashamed:Ipriced out a snowblower from him once ,but found one 1000 cheaper ,so now im relly feeling rotten.Mabey ill order a woods blade from him that will fit my landscape rake frame
ALAN
   / will my bx23 haul a 5ft box scraper? #9
ALAN
Maybe you should move ?:laughing:
   / will my bx23 haul a 5ft box scraper? #10
Hey, economics is just that. You got the best product for the best price you were comfortable with. Nothing wrong with that!:)
2000 Freightliner FC-70 Sweeper (A47371)
2000 Freightliner...
2008 Ford Expedition SUV (A45336)
2008 Ford...
2006 Toyota Solara Coupe (A46684)
2006 Toyota Solara...
2009 CHEVROLET SILVERADO 2500HD (A47001)
2009 CHEVROLET...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A46683)
2025 Kivel 48in...
2003 VIKING TRAILER CEMENT MIXING TRAILER (A47001)
2003 VIKING...
