Ballast Will these suitcase weights fit my BX2660?
   / Will these suitcase weights fit my BX2660? #1
Lumberdink
Billtown PA
Found these suitcase weights on CL They're about an hour away so if they won't fit my BX2660, please let me know and save me a trip. :thumbsup:
Also, is a buck a pound a good price for these? They are 44 pounds each. How many should I get, assuming they fit? I will use them with my rotary cutter and probably a plow or disc later this spring with the FEL removed.
Here's what the seller says:
I'm not sure how big your Kubota is but if there's a bar to put them on, you can see.
The weights are 1 3/4 in thick. 16" to top of handle of them. 9 1/4 to back of hook, 6 1/2 in to hook stop.
We can sell them individually. Each one is approx 44 lbs.
   / Will these suitcase weights fit my BX2660? #2
New ones are about $1.25 a pound at HD and Lowes, and they can probably be returned if they don't fit.
Bruce
PS---given the implements I want to use, how many pounds will I need? :confused:
   / Will these suitcase weights fit my BX2660? #5
__________________
2011 Kubota BX2660 with LA243 FEL and Loaded AG Tires
Bro-Tek Rear Wheel Spacers
Borrowed 4' Kubota Rear Blade
Woods XT148 Rotary Cutter
Curtis Sno-Pro plow
Recommendations may be in your tractor manual. I'm pretty sure my BX2360 manual has counterweights listed.
Bruce
Funny you mention the manual---I'm currently reading it cover to cover (with almost 50 hours on my BX)! :ashamed:
2014 CS&P  BLENDER (A45333)
2014 CS&P BLENDER...
40ft 5 Dual Door Shipping Container (A44571)
40ft 5 Dual Door...
LOAD OUT AND SHIPPING (A44391)
LOAD OUT AND...
2020 Freightliner Cascadia T/A Sleeper Cab Truck Tractor (A45336)
2020 Freightliner...
2001 KENWORTH T300 FLATBED DUMP TRUCK (A43004)
2001 KENWORTH T300...
2018 Ford F-350 Knapheide 9ft Crew Cab Dump Truck (A44571)
2018 Ford F-350...
