Ballast Will these suitcase weights fit my BX2660?
   / Will these suitcase weights fit my BX2660? #1
Lumberdink
Billtown PA
Found these suitcase weights on CL They're about an hour away so if they won't fit my BX2660, please let me know and save me a trip. :thumbsup:
Also, is a buck a pound a good price for these? They are 44 pounds each. How many should I get, assuming they fit? I will use them with my rotary cutter and probably a plow or disc later this spring with the FEL removed.
Here's what the seller says:
I'm not sure how big your Kubota is but if there's a bar to put them on, you can see.
The weights are 1 3/4 in thick. 16" to top of handle of them. 9 1/4 to back of hook, 6 1/2 in to hook stop.
We can sell them individually. Each one is approx 44 lbs.
   / Will these suitcase weights fit my BX2660? #2
New ones are about $1.25 a pound at HD and Lowes, and they can probably be returned if they don't fit.
Bruce
PS---given the implements I want to use, how many pounds will I need? :confused:
   / Will these suitcase weights fit my BX2660? #5
__________________
2011 Kubota BX2660 with LA243 FEL and Loaded AG Tires
Bro-Tek Rear Wheel Spacers
Borrowed 4' Kubota Rear Blade
Woods XT148 Rotary Cutter
Curtis Sno-Pro plow
Recommendations may be in your tractor manual. I'm pretty sure my BX2360 manual has counterweights listed.
Bruce
Funny you mention the manual---I'm currently reading it cover to cover (with almost 50 hours on my BX)! :ashamed:
2017 INTERNATIONAL 4300 26 FT NON CDL BOX TRUCK (A43004)
2017 INTERNATIONAL...
Tree Boom (A44502)
Tree Boom (A44502)
2016 Peterbilt Tri-Axle Dump Truck (A42203)
2016 Peterbilt...
(10) 2" Ratchet Straps (A44502)
(10) 2" Ratchet...
2017 PETERBILT 579 TANDEM AXLE SLEEPER (A43003)
2017 PETERBILT 579...
Giyi Quick Attach Backhoe (A44502)
Giyi Quick Attach...
