Wireless pet fence??
   / Wireless pet fence?? #11
Coyotes? Skunks?
I'll soon be building in the middle of my 100 acres. Approximately 2 acres around the home will be inside chainlink fencing. I figure a good fence is as much for protection of my pets as anything else.
Coyotes? Skunks?
To each his own.Good luck on your building project.
   / Wireless pet fence?? #13
We bought one when our dogs were young because we didn't want them in the poison oak and didn't want the neighbors to shoot them which is legal around here. Back then, it cost $400 but worth every penny. The dogs were trained in two weeks and even before that, they would not go near the little flags you put out around the perimeter which makes the boundary visible to them. After 13 years, they never left the yard unless we were with them. We sold the system after a short while for almost what we paid for it. Can't recommend them enough. It can save the dog's life. Wireless is the only way to go, I think.
   / Wireless pet fence?? #14
I have the pet safe wireless unit on my Anatolian Pyrenees she's s big aggressive guard dog ... I love the unit and would not consider anything else she knows her boundaries and doesn't test it .. They said to show her the boundary and set flags .. I set the shock up high walked away and she discovered it on her own !!
Other critters that "come in" to her area generally don't leave !!
I recommend them .. At least for my situation .. The batteries at first in the collar didn't last long .. I guess cause she was testing it .. Now I seem to get about 90 days.
   / Wireless pet fence?? #15
The thing about the guardian breeds is that they are bred to a sense of territory (or should be), that is their standard.
On the other hand the Britney's are a hunting dog with no innate sense of territory.
If the dog (the Brit) is from good working stock I'd no more trust an invisible fence then just allowing the dog to roam free and hope the dog makes it back home.
   / Wireless pet fence?? #16
The thing about the guardian breeds is that they are bred to a sense of territory (or should be), that is their standard. On the other hand the Britney's are a hunting dog with no innate sense of territory. If the dog (the Brit) is from good working stock I'd no more trust an invisible fence then just allowing the dog to roam free and hope the dog makes it back home.
Well now when a stranger or a wild critter comes around that 100lbs of stand up hair, going aggressively towards that boundary ... Well it stops her. I'd find it hard to believe that a smart breed such as a Brit wouldn't as we'll be trained to the boundary with a wireless system.
H,mm a Brittany has no sense of there own territory.Have you ever owned this breed?Got to disagree.This is our 4 britt in the last 35 years and they DO know there own territory and surroundings
Thanks good info.This unit has the rechargeable battery.
   / Wireless pet fence?? #19
I have had one of these systems for years. Put 3 different dogs through the training. Key thing, particularly with stubborn breeds is to set the collar to max stimulation level from the outset. If the system has enough sting, the dog only tests it 2 or 3 times then its done. If you use level 2, some dogs will simply tolerate it while continuing to do what they intended.
The wireless collar works differently to the buried wire. The collar received 2 radio signals, a stronger one to know that it is near a transmitter and a weaker one that is adjustable for the boundary. The system has a high/low power mode + a rotary wheel for fine tuning. When the weaker signal reaches its critical threshold, that is considered the boundary. The collar will continue the shock treatment for up to a certain time (20-30 seconds) once the animal is past the boundary. Then it will lock out until the animal comes back over the boundary. So dogs that do violate the boundary are able to return after enduring an extended zapping.
I have not yet met a dog that is willing to endure the 20 seconds more than just a couple of times. Our Minipin was extremely resistant, she would simply ignore a regular "training" collar. Once we had her sterilized she calmed down a bit...
We just had our britt. neutered but she,s still he!! bent.Thanks for the information.I guess we will order the unit.
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A55787)
2014 JLG G12-55A...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2014 MACK ELITE...
2008 KOMATSU PC200LC-8 EXCAVATOR (A52706)
2008 KOMATSU...
Galvanized Livestock Gates - (2x Gates) (A55218)
Galvanized...
GMC 3500 Extended Cab 4WD Pickup Truck - 6L V8 Gasoline Automatic (A55218)
GMC 3500 Extended...
2013 BMW X5 xDrive50i AWD SUV (A55758)
2013 BMW X5...
