Teikas Dad
I use full synthetic in my Kubota B3200 for engine oil. Rather than using Kubota filters I want to put an oil filter on the tractor made for synthetic oil. Wix lists their model 51334 as a correct cross referenced filter for my Kubota, it lists Kubota and a number of other tractors on their data sheet. They also show the 51334XP filter which has synthetic media rather than cellulose. Both filters fit the same gas engine cars that they have listed, doesn't matter if it's the regular or XP filter. I'm just trying to figure out if the XP filter would work on the tractor.
Anyone use a Wix XP filter on theirs? Any other thoughts?
From Wix website:
Product Specifications
Part Number: 51334
UPC Number: 765809513341
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Enhanced Cellulose
Height: 3.194 (81)*
Outer Diameter Top: 3.252 (83)*
Outer Diameter Bottom: Closed:
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=6/20
Burst Pressure-PSI: 280
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 21
Note: Holds 40% More Contaminants Than Other Leading Brands - Has Silicon Anti-Drain Back Valve To Prevent Dry Starts:
Operating Temp. (min): 0
Operating Temp. (max): 0
Capacity: 9
Filter Area: 0
( )* denotes metric
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.475 (63)* 2.173 (55)* 0.233 (6)*
Principle Application:
Principle Application: Acura (88-05), Chevrolet (85-88), Dodge (91-96), Ford (88-96), Honda (72-09), Hyundai (89-15), Isuzu (85-04), Kia (01-15), Mercury (87-91), Mitsubishi (89-98), Subaru (87-15) Atlas-Copco, Case, John Deere, Kobelco, Komatsu, Kubota, Onan, Toro & Yanmar Diesel, Other
All Applications
Part Number: 51334
They list the following for the 51334XP filter:
Part Number: 51334XP
UPC Number: 765809216860
Service: Lube
Type: Full Flow
Media: Synthetic
Height: 3.194 (81)*
Beta Ratio: B2=20
Capacity: 0
Filter Area: 0
( )* denotes metric
Gasket Diameters
All Applications
From Wix website:
Part Number: 51334
Service: Lube
Type: Full Flow
Height: 3.194 (81)*
Capacity: 9
Filter Area: 0
( )* denotes metric
Gasket Diameters
All Applications
Part Number: 51334
Service: Lube
Type: Full Flow
Media: Synthetic
Height: 3.194 (81)*
Beta Ratio: B2=20
Capacity: 0
Filter Area: 0
( )* denotes metric
Gasket Diameters
All Applications
