Wobble Drain
/ Wobble Drain #1
KubotaL5740
Felton, PA
kubota
I have a Kubota L5740 and I notice a little oil coming out of the wobble drain. Naturally, this is the first time I noticed it. I called the dealer and this should not be happening this box is suppose to be dry at all times. This means I have a leak internally. Short of the story, the tractor has to be split in half to fix the issue. Estimated cost $4600.00. Anyone every had any experience with this?
/ Wobble Drain #2
I'm not familiar with the term 'wobble drain' and there's nothing on google to point me in the right direction (other than this thread).
It sounds like something I could/should monitor every now and then... please explain. Ta, Mate.
/ Wobble Drain #3
In a bell housing they drill a small hole at the bottom to release any oils that might get pass the end crankshaft seal.
Usually that drain hole is about 1/8-3/16 and in order to not let it plug up from crap they install a slim cotter pin with the end slightly split but not trimmed.
Vibration causes that cotter pin to 'wobble' and keeps the hole open for drainage thus preventing oil accumulation in the housing.
This is particularly important for clutch drives as clutches and oil do not go well together.
/ Wobble Drain #5
did you check the gearbox dipstick?
/ Wobble Drain #6
And how many hours on tractor? Those seals are pretty durable generally.
Jim
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
New/Unused AGT Industrial SDA-140T Track Loader (A65579)
New/Unused AGT...
2007 KOMATSU PC35MR-2 TRACKED LOADER EXCAVATOR (A59914)
2007 KOMATSU...
LAYMOR SWEEPMASTER 400 (A65643)
LAYMOR SWEEPMASTER...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
1901 HOMEMADE 16FT T/A TILT TRAILER (A59906)
1901 HOMEMADE 16FT...
