Wood Splitter
/ Wood Splitter #1
garbageman
Orange County, NY
Kubota 7500
I was looking to buy a splitter (not a 3 Pt) to split 4-5 cords of wood a year. I don't require anything heavy duty, just dependable. Any recommendations?
Ray
/ Wood Splitter #2
You can do a search here on Tractorbynet - there have been a few threads on log splitter recommendations. If you are looking for something that is reliable , fast and easy to use check out the Super Split Log splitters - my father bought one of these probably 20 years ago and has pretty much no problems with it - he got the electric version but you can also get a gas version. If you are handy you could probably even rig one of these to run off of tractor hydraulics. The stuff they claim in the website is pretty much true - this thing will split wood as fast as you can load the logs in - every hydraulic splitter I have used you always have to wait for the hydraulics. Not sure on the pricing - I think they are more expensive than hydraulics but the long term reliability should more than make up for that extra cost.
/ Wood Splitter #3
I have an MTD 6 HP, 23-ton splitter and I am very pleased with it. I bought it used on Ebay for $800. I was less than a year old when I bought it. I have split about 50 cord of wood so far this season without any problems. Although the 18 second cycle time is a little slower than some of the more expensive units, it has no problem with any of the oak or maple I have run thru it.
I was originally looking at a Timberwolf splitter, but I can buy three of the MTD machines for the cost of one Timberwolf.
/ Wood Splitter #4
The type and size of wood you normally harvest for fire wood is going to be one factor. If it is fairly straight easy splitting stuff and you have all the time in the world to split it then look at some of the less expensive models.
Home Depot rents the splitters they sell so you can get a good idea of how it will perform. I purchased a Super Split wood splitter this past spring, it is a fantastic unit.
The price of this unit is equal to the high end hydraulic wood splitters but then it is a high performance splitter. There are no hydraulic components to worry about leaking. The splitting cycle time is 3 times faster than the faster hydraulic units. My son and I split a cord of hard wood, maple and oak, in 20 minutes.
One thing to keep in mind when you own a splitter it is intresting how many people would like to borrow it.
Randy
/ Wood Splitter #5
I purchased a Brave Products splitter in the spring and have been pleased with it. Bought it through Baileys who remark it with their label. After talking with the factory guyz at Brave, I did upgrade to the Honda GX engine. I am splitting about the same volume of wood as you on a yearly basis and this machine seems perfect.
Bob - Oregon
/ Wood Splitter
I was looking for a 20-27 ton splitter for $900-1200 dollars. Looked in Home Depot, Lowes and some tractor suppliers who
sold "better quality" but were big bucks. I would like a dependable machine, no rush splitting.
Thanks for the replies,
Ray
/ Wood Splitter #7
I bought a 30 ton splitter with an 8 hp Briggs OHV engine for $998 about three months ago from Harbor Freight. Free shipping. It seems well made, very heavy, and has plenty of power. It is $1098 now, and that's what it was when I ordered it. They sent out a flyer just after I ordered and before it arrived, dropping the price to $998. I called them and they refunded the difference. I was leery of buying it sight unseen. I am happy with it.
/ Wood Splitter #8
I have the Yard Machine (MTD) 6hp / 25 ton model that Home Depot sells. I think it was $899. I've used it for 2 years and it seems very adequate for my use. I've done about 10 cords with it so far.
Greg
/ Wood Splitter #9
Logan and Grej......What are the cycle times on you units?
I've been looking at HF and HD units as well.
Chris
/ Wood Splitter #10
CTyler,
Here is the link to my splitter MTD Yardman Splitter . As far as cycle time, I never let it go full cycle. I stop the ram around the length of the logs I am splitting, so I limit the amount of travel. This machine works plenty fast enough for my 52 year old body. I wouldn't want to go any faster. A friend of mine was using a fast cycle unit years ago and lost the end of his thumb. I guess I really shouldn't blame the splitter for that, but it is nice to have a second or two to watch what's happening.
Greg
/ Wood Splitter #11
The advertised cycle time on mine is 15 seconds but like Greg, I only use about half a stroke and the ram automatically retracts when you let go of the lever. I guess they all do that but I'm not sure. HF also has a 24 ton model, also with an 8 hp Briggs engine. I don't know if it is the same engine model as mine. It is $899.
I looked at the MTD splitter at Lowes (like Greg's) and mine is built with what looks like the same heavy material. Both are well built. The MTD has a log cradle, mine does not. Mine holds five gal. of hyd. fluid and the MTD looks about the same.
The MTD 6 hp model was a verticle shaft engine where the Harbor Freight is horizontal. I don't think that would make any difference. The MTD model has fenders, that might be necessary for road use in some states. Mine has no lights and I don' think the MTD splitter had them either. I will not be towing mine on the highway so that wasn't a issue.
Another thing, the wheels on the Harbor Freight model don't use lug nuts. Not sure on the MTD model, but from the picture they appear to be the same as mine. The wheel and hub are one unit. You have to take the bearing out to change the tire. Still not much of a concern for me because I will slime them if I start getting leaks and I will not be pulling it on the road.
I went with the Harbor Freight model because of the extra hp and 16 gpm two-stage pump, plus no sales tax and free shipping, but I don't think you could go wrong with either one.
I have split some well seasoned oak (about 16") that I couldn't split with a maul, or sledge hammer and wedges last season when it was green. A lot of it had limbs. Really tough to split for a 53 year old with a bad back. This thing split it like butter. It also has NEVER failed to start on the first pull of the rope.
You have to assemble the HF model. You have to mount the beam and put the wheels on and pack the bearings, and you have to bolt on the coupler. Pretty easy but its a two man job to put the beam on and line it up for the bolt. Did I say this sucker is heavy? Plan to have help unloading it when the freight company brings it. Luckily I had a front end loader.
/ Wood Splitter #12
Thanks for the info guys.
I have pallet forks. /forums/images/graemlins/grin.gif
/ Wood Splitter #13
Garbageman, I would have to agree with you. No need for rush splitting. 15-18 second split time for the "slower" hydraulic models? Heck, it takes me that long to hit the wedge the first time with the sledgehammer!
/ Wood Splitter #14
Hello,
Bought a used wood splitter today.Its a lickity splitter made in piqua ohio in the 1970s.Would like to find a manual for this wood splitter or maybe some pictures.Would like to know more about the controls and levers.Thanks Rick:(
/ Wood Splitter #15
There are a lot of good splitters out there. Two things I would reccomend is that you get one that can be operated horizontal and vertical, and that is powered by its own gas engine. The ones that are only horizontal are usually too low to operate comfortably standing up, and too high for getting real big pieces up on. This is a recipie for a sore back. With the horizontal/vertical ones, the height is perfect while horizontal for standing up working on smaller stuff, and when you move them vertical, you can easily roll the big pieces into them and sit on a chair as you split them. When I am splitting, I hook the splitter up to a front bumper hitch on my Ford 8n and pull it out of the barn to where the wood is. I then back the tractor up to the spliter and load a 3pt caryall as I split, using the tractor to haul it back to the woodshed when it fills up (aprox 1/2 cord capacity). This is sure a lot handier than when I had one that operated off the tractors hydraulics and it cuts way down on the fuel usage. Other nice features are a 2-stage pump and an automatic return.
/ Wood Splitter #16
/ Wood Splitter #17
How much you have to split and the size of the logs and frequency will all impact the decision.
I purchased a Ryobi electric splitter for $299. Pro's and Con's.
1) Price
2) Electric - no maintenance other than change hydraulic fluid once in a while
3) Size - small ,will fit anywhere
4) Power to size - rated at somewhere around 4-5 ton, I've not hit a log yet that I could not split, I've split up to 18 inches or so in diameter hardwood
5) Super Safe - must use two hands to opperate, very slim chance you'd hurt yourself.
Con's
1) It is very low to the ground, some have set up a little stand or put on blocks
2) Need electricity - I can run off of my generator if need be.
This machine has been perfect for me, I'd recommend to anyone. Others have given superior reviews as well.
I am just happy not to have another gas motor to worry about.
Good luck,
joel
/ Wood Splitter #19
I am looking to build one and could use the help with plans or designs with this project. Nothing to heavy duty, I have an idea just need help with getting started.
/ Wood Splitter #20
Search and you'll find a number of threads.
I considered the same, but the amount of work invovled for something that I'd not be using all that much just did not seem worth it when I could purchase a new machine for $299 that does a great job.
This is one of those projects that seems like it would be interesting to build but just not worth the effort unless you are going for something very custom for a particular application.
Even if I needed industrial strength and volume I'd probably purchase something used.
The parts can add up fast.
Joel
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
2006 Hitch and Trailers Inc. 12ft S/A Utility Trailer (A61574)
2006 Hitch and...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2022 CATERPILLAR 299D3 XE SKID STEER (A64279)
2022 CATERPILLAR...
10ft Cattle Panels (A64047)
10ft Cattle Panels...
