Wood splitting, what do you do with your slag?
   / Wood splitting, what do you do with your slag? #21
Bigger pieces go in the stove, smaller stuff is used for mulch!
   / Wood splitting, what do you do with your slag? #22
I usually wait until the end of splitting time, blade it into a big pile and burn it with all the crotches and punky wood. I then shovel the ash into the loader and spread it in the woods.
   / Wood splitting, what do you do with your slag? #23
I took a half yard of splitter waste and dumped into two mudholes on my one gravel road. Absorbs some of the water and helps prevent further washout. That's the theory anyway!
   / Wood splitting, what do you do with your slag? #24
Split firewood is easier to use for heat. So I rake up the trash and use it to bury in my Hugelkulter (google it) beds. I use that carbon to soak up water for the crops to feed off of as it decomposes.
   / Wood splitting, what do you do with your slag? #26
It was supposed to be hugelkultur. But your right. Dirt is dirty. :thumbsup:
   / Wood splitting, what do you do with your slag? #29
Whatever burns never returns.
2016 ELDORADO NATIONAL EZ-RIDER CNG BUS (A58018)
2016 ELDORADO...
Mini -Excavator Heavy Duty Rock Ripper (New/Unused) (A59225)
Mini -Excavator...
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A55973)
Miller and Smith...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
