wood stove & ceiling fan
   / wood stove & ceiling fan #11
I can heat my whole 2000sf house with our 34K BTU air-tight wood
stove. If I do not run the ceiling fan(s), our feet get cold, exacerbated
by the fact that the ceilings are 14-ft high at their peaks. High
ceilings make the fans necessary, rather than optional.
   / wood stove & ceiling fan #12
I think this is one of those things that you have to try and see how/when it works for you.
Our ceilings are 10 feet tall. Turning the fans so the blow up to the ceilings does seem to add a degree or so to the "human" space. In the past I would still feel a breeze so we would turn off the fan. Because of this thread I tried the fans again. I think we where warmer but the stove was really burning so I can't tell if the temp went up because of the fan or not. We did not feel a breeze though.
So what that tells me is that there is a minimum temperature that the fan can be operated without the fan being negatively felt. I'm guessing in our house its about 80.
I'll still play with the fan off/on for grins and giggles but me thinks in our house with our stove it does not matter that much if it runs or not.
Later,
Dan
   / wood stove & ceiling fan #13
Up in winter & summer in my case. Have log home with open lofts
on each end of open living, dining and kitchen area. This helps keep
the temperatre more even through-out the whole house during heating
or cooling. Forced air in winter; AC in summer. Works good for me.
Fans located in each of the 2 lofts. Lofts stay cooler this way.
Another follow-up question with our new wood stove...
Last night we had a very noticable amount of smoke in the house from the wood stove. My suspicions are because of some extremely high winds here in northwestern PA. Would this make sense or should this never happen?
Thanks...
coachgrd
   / wood stove & ceiling fan #15
Coachgrd,
Is the stove connected to a pipe that supplies outside air for combustion?
I have seen some information that this could cause drafting problems in high winds. The article might have mentioned problems with draft in high winds with a stove that was not connected to outside air but I don't remember for sure. Our stove is connected to a 6 inch pipe to supply combustion air.
Was the smoke coming from the chimney or from the stove?
I have seen a bit of smoke leaking from the stove when we where starting a fire and there where very few ashes in the stove. The smoke was leaking from the ash box under the stove. Not enough ashes in the stove to seal the plug to the ash box.
Later,
Dan
   / wood stove & ceiling fan #16
When I had my stove it took a little to heat up the stovepipe when starting a fire. The pipe needs to be hot (or at least warm) to get the desired upflow to the colder outside air. When I started fires before it was too cold out (say ~40), I could easily get smoke in the house if I got the fire going too quickly. I didn't want a fire going until the outside temp was below 30, otherwise the house just got too warm.
dmccarty said:
Coachgrd,
Later,
Dan
Dan:
Other than the smoke pipe, there is no other vent pipe. I'm not quite certain where it gets it's fresh air to fuel the fire.
I just called the installer and was told that it is not uncommon for this to happen in extremely high winds, whicj is what I would characterize last night's as. They said they do sell a high wind cap for about $100.00
coachgrd
gd
   / wood stove & ceiling fan #18
i "I'm not quite certain where it gets it's fresh air to fuel the fire."
It's drawn into the firebox through a vent on the bottom of the unit. The damper you adjust is what controls the size of the opening. It doesn't take much air to keep a fire smoldering red hot. The glowing coals are what produce the most heat, so if you want the best heat output get a good bed of red hot coals going. If want ambiance, well, that's where the flames come in...
In general: more air = more heat = quicker burn = more wood required.
Once the fire has a good bed of coals, close down that damper as much as you can to keep things smoldering, but not flaming. That will give you a good amount of heat while lasting a good long time. With mine, I could stoke it up before going to work and still have it blowing warm air when I got home 10-12 hrs later, with no interference from the wife during the day.
   / wood stove & ceiling fan #19
Since you already have a forced air system in your house, why not just run the fan from your furnace to circulate the warm air from the wood stove through your house?
Hmmm, you might be onto something there...thanks.
8' LARGE FENCE POSTS (APPROX. 20-25 PC) (A54756)
8' LARGE FENCE...
UNUSED PE Industrial Stretch Wrap Rolls (A53117)
UNUSED PE...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55301)
UNVERFERTH 330 -...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2010 Cadillac SRX SUV (A55758)
2010 Cadillac SRX...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
