Chipper Woodland Mills Chipper WC68 Review
   / Woodland Mills Chipper WC68 Review #41
I got the WC88 in June, love it running on a 80 hp tractor set pto on 1000 and engine rpms on 1100, runs great chips every thing I'v put at it. A friend of mine has a wood max but the wc88 is built to last, alot of steel!
Brian
   / Woodland Mills Chipper WC68 Review #42
Absolutely no regrets. Even at 21 hp at the PTO, I can readily handle 3-4 inch. Those with more tractor, only the better.
   / Woodland Mills Chipper WC68 Review #43
Pulled the trigger on a WC68 today. Hopefully it will be here by the end of the week.
When I talked to the sale person they said I need 5 gallons of ISO 32 hydraulic oil. Any recommendations on a brand or where I could find it ? We have TSC, Rural King, Wally World, and pretty much any place under the sun. I figured TSC would have it but it doesn't look like they do. Wally World has Sinopec, I've never heard of them.
   / Woodland Mills Chipper WC68 Review #44
I bought mine from NAPA. Not sure the brand matters as long as the proper weight
   / Woodland Mills Chipper WC68 Review #45
Thanks, we actually have a NAPA in the small town I live in. I'll give them a call.
   / Woodland Mills Chipper WC68 Review #46
Mcastles, you're way ahead of me on WC68 work time :) I've had mine for about 3 weeks. It certainly works flawlessly - and a LOT faster than I can feed it. Yesterday I chipped one cubic yard of chips in less than an hour. I know it was 1 cuyd because I used the cardboard box that covered the chipper when shipped.
I put the box on a little m/c trailer, filled the box and and spread the chips in the garden. That system was a pretty good one-time event though. I had to tear up the box to get the chips out. I suppose a small dump trailer would be ideal, but I didn't see one sitting around in my tool area. Minor problem - I'll deal with that.
Most of my chipping was 2" - 4" trees, but still had a good many 6" size. I haven't changed the pressure springs on the feed roller, so feeding the 6" size was difficult until I learned that feeding a smaller size tree first and adding the larger ones closely following it proved to be an easy feed system. I'm guessing that cutting the tree butt at an angle would eliminate that problem.
Never had anything like a jam or hesitation. I've slowed down the feed speed some to let the chipper produce very small chips. Even at that, the WC68 works me more than enough. So far, I'm elated over the quality of the WC68. Right price, easy to set up and use, and works faster than me :)
is your FEL bucket quick connect? set a couple blocks down, set the front on it to raise it, and take it off and chip into it. when it's full, go dump it where you need the chips. I've done this with mine and it works pretty well
That is one of the best ideas I've got from TBN!
   / Woodland Mills Chipper WC68 Review #48
I've been wanting a wood chipper for quite awhile. This review and the videos from Woodland Mills convinced me this is the one for me.
Ordered an WC68 on Oct 18th and received it 11-1-18. Got it assembled on Saturday and began use. My gosh, I am so impressed with it's smooth and easy operation! I now see that I should have bought one a 'Long' time ago.
I am also glad to have chosen the hydraulic feed option; I don't have anything big enough to choke it out but have noticed that some branches will clog slightly and its quite easy to just bump the lever and back out for a fresh start. Everything I feed it, once it gets under the roller wheel, it just eats it up.
No challenge to the tractor at all. I have approx 21 PTO Hp and it easily eats what I feed it. I was going to take pictures but they are exactly as BLSXJ has already posted so I didn't spend any time with a camera, just bolt, check and go to work.
I went to our NAPA and they had the ISO32 Hydraulic oil. Which is really just AW 10 W hydraulic oil. $57.15 for a 5 gal can.
The only thing I found when putting it together is that the lower flap of the feed shoot doesn't quite sit flush with the main base. I took it apart and re-assembled it 2 or 3 times to see if I was doing something wrong or what. Nope. It just rests slightly lower than its matching mate. That causes some of the very small branches to catch while pushing them up into the roller. Not a problem overall and once aware of it it is easy to overcome. I may get creative with some sort of fix at a later time. For right now it's just feed and watch chips flow from the discharge chute! I'm quite jazzed with this new attachment and I'm kicking myself for waiting so long to get it. Very satisfied with the Woodland Mills machine.
Thanks BLSXJ for posting your review; it led me to decide on this machine and I'm very happy! Greg
Just a quick update. I've been chipping a bunch of dead pine and I've now clogged the discharge chute for the 1st time. This is news because I've got maybe 30 hours of chipping on the machine... and this is the 1st its happened.
how it happened... the FIL was over "helping" us clean up a small section of bush... btw he loves the chipper. I caught him a few times sticking a branch in and just starring at it getting chipped! After one of our breaks... I started up the tractor, engaged the pto, and started to move the rpm's up to pto speed.
well Mr. Eager Beaver saw the infeed roller start to spin, and jammed a 4" limb in.... I look back from the tractor, now at 540, and it sounds off and I realize nothing coming out the discharge chute!!!!
I must have given the universal "OH POOP" signal, and the FIL reversed the infeed roller. I shut down the tractor, and opened the clam shell with that Princess Auto (harbor freight) wrench I keep in the document holder.
i took a bit of work but I cleared the jam.
lesson learned..... wait till the chipper is up to speed before you... your helpers, start!
just another example of Intel inside...idiot outside!
2023 JOHN DEERE 8R310 LOT NUMBER 202 (A53084)
2023 JOHN DEERE...
KMC 3376 LOT NUMBER 227 (A53084)
KMC 3376 LOT...
2011 GLOBAL 130BBL VAC TRAILER (A52472)
2011 GLOBAL 130BBL...
1028 (A51572)
1028 (A51572)
LEGEND  2615 (15) BAT WING (A52472)
LEGEND 2615 (15)...
Adams 8 Ton Weigh Hopper (A52748)
Adams 8 Ton Weigh...
