Woods BB 720 with emulsified gear box oil
   / Woods BB 720 with emulsified gear box oil #11
Have you given it a though to drill a hole in
the bottom to drain it and tap and put a bolt
or purchase a plug to put in it?
willy
   / Woods BB 720 with emulsified gear box oil #12
Bought a Alamo flail with the same problem. Previous owner said he changed the gear oil. It does have a drain plug. Could not tell if fill plug vented so replaced with a sintered bronze vent plug. Before it had some pressure.
Gear oil is made to emulsify with water to suspend contamination. Changing it will remove water. Might take a couple of times.
17 years outside will kill a rotary cutter in our climate. We try to keep that kind of equipment under cover or put tin roofing over gearbox.
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
(2) UNUSED 3500# IDLER AXLES (A51247)
(2) UNUSED 3500#...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A53472)
2003 International...
2018 Link-Belt LBX 300X4 Hydraulic Excavator - Aux Hydraulics - 6388 Hours Showing - 24 In Bucket (A53472)
2018 Link-Belt LBX...
