Woods BB840. How to reset or fix blade
   / Woods BB840. How to reset or fix blade #1
coffeeman
Platinum Member
Hi all
Hit a chunk of iron tonight. The cutter stopped fast. I shut down pto. Pulled iron out and noticed one of the two blades was moved out of way and stopped over the round disk blades bolted to; moved about 60 degrees and out of cutting path. Looked in the manual and got no idea what to do. I don't know if the blade is spring loaded, sheer pinned or just broke. I'm guessing it is on a hinge or spring. How would I move blade back to home base? I haven't started cutter back up yet. I sliced my leg on iron after trying to fling the iron onto my junk pile. I thought I'd call it a night.
Cheers....Coffeeman
   / Woods BB840. How to reset or fix blade #2
Hmmm....sounds like the blade is doing what it's supposed to do. I don't know that rotary but with my bushhog, the blades are hinged in the center and rotate out with centripital force when the rotary spins up. Do you have a picture?
   / Woods BB840. How to reset or fix blade #3
Coffeeman,
The blades rotate freely about the pin. Your blade is probably either slightly bent from the contact, or more likely has some grass/junk pinning it there. Get a long pole or a shovel and whack it out. Just hit the back side of the blade!
If it bent and won't freely rotate, you should buy a new blade. They have a VERY specific heat treatment and shouldn't be bent back. Some people do take them off and give em a few whacks with a sledge hammer, but it is not recommended - even though it works 99.9% of the time. The other 0.1% of the time, the blade snaps in two in use and sends the other half flying out to cause mayhem, mischief and possible death. Your call.
jb
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
2000 Genie Z45/25 Manlift (NOT RUNNING) (A50774)
2000 Genie Z45/25...
JOHN DEERE 3 BOTTOM PLOW (A51243)
JOHN DEERE 3...
(3) UNUSED FUTURE JUMPER CABLES (A51243)
(3) UNUSED FUTURE...
Unused 2025 CFG QK18R Mini Excavator (A50322)
Unused 2025 CFG...
