Woods BB840. How to reset or fix blade
   / Woods BB840. How to reset or fix blade #1
coffeeman
Platinum Member
Hi all
Hit a chunk of iron tonight. The cutter stopped fast. I shut down pto. Pulled iron out and noticed one of the two blades was moved out of way and stopped over the round disk blades bolted to; moved about 60 degrees and out of cutting path. Looked in the manual and got no idea what to do. I don't know if the blade is spring loaded, sheer pinned or just broke. I'm guessing it is on a hinge or spring. How would I move blade back to home base? I haven't started cutter back up yet. I sliced my leg on iron after trying to fling the iron onto my junk pile. I thought I'd call it a night.
Cheers....Coffeeman
   / Woods BB840. How to reset or fix blade #2
Hmmm....sounds like the blade is doing what it's supposed to do. I don't know that rotary but with my bushhog, the blades are hinged in the center and rotate out with centripital force when the rotary spins up. Do you have a picture?
   / Woods BB840. How to reset or fix blade #3
Coffeeman,
The blades rotate freely about the pin. Your blade is probably either slightly bent from the contact, or more likely has some grass/junk pinning it there. Get a long pole or a shovel and whack it out. Just hit the back side of the blade!
If it bent and won't freely rotate, you should buy a new blade. They have a VERY specific heat treatment and shouldn't be bent back. Some people do take them off and give em a few whacks with a sledge hammer, but it is not recommended - even though it works 99.9% of the time. The other 0.1% of the time, the blade snaps in two in use and sends the other half flying out to cause mayhem, mischief and possible death. Your call.
jb
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
1/2 HP 300-1200 RPM Drive Motors (A47384)
1/2 HP 300-1200...
P.T 8' Offset Disc Harrow (A50120)
P.T 8' Offset Disc...
8'x8' Aluminum Cover (LOCAL TOWNSHIP) (A50774)
8'x8' Aluminum...
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
Super Star Smithco Bunker Rake (A50322)
Super Star Smithco...
