WORK LIGHTS
   / WORK LIGHTS #1
BX23RIDER
Beech Creek PA
KUBOTA BX23
I PUT TWO 55W LIGHTS ON THE ROPS & CONNECTED THEM TO THE TWO WIRES UNDER THE SEAT, THAT GOES TO A 20AMP FUSE MARKED WORK LIGHT BY THE BATTERY. I WILL NOT BE USING THEM ALOT 30 MIN OR SO. DO I NEED THE HIGHER OUT PUT ALTENATOR ?. WILL IT HURT ANYTHING USING THE ONE IT COMES WITH. THANKS BX23RIDER. PS I DO ENJOY YOUR DISCUSSIONS.
   / WORK LIGHTS #2
IS IT REALLY LOUD WHERE YOU ARE? IF IT IS, I'LL KEEP SHOUTING SO YOU CAN READ THIS.
All kidding aside, welcome to TBN! I have a BX22 that I rigged the same way. You should be fine with that setup and the stock dynamo. I've use my lights and headlights at the same time for hours at a time while shovelling snow without any problems.
   / WORK LIGHTS #3
I don't think you will have a problem as long as you don't run any other high draw equipment at the same time. I think two 55 watt lights draw about 11 amps. I run one 55 watt halogen on the rear with the same hookup as you. I can run it along with the headlights and flashers and I have had no problems.
Dean
   / WORK LIGHTS #4
I run (2) 55 watt facing forward and (1) facing rearward on my BX1800 with the stock alternator and have had no issues. I don't run the stock lights at the same time, but do sometimes run the flashers when near the road.
   / WORK LIGHTS
THANKS FOR THE INFO, NOW I CAN SEE WARE I AM GOING. HA HA. /forums/images/graemlins/smile.gif
   / WORK LIGHTS #6
Randy, do those lights have a magnetic base?
Do you have any pics of your plow and receiver hitch? I'm just curious about how you put it together.
Dean
   / WORK LIGHTS #7
The basic formula used is P=I*E or watts=amps * voltage. Using basic math to solve the equation when amps is the unknown, you would have amps=watts divided by voltage.
So for two 55w bulbs you would have an amp draw of just over 9 amps. Three 55w bulbs would draw about 13.75 amps.
I believe the standard dynamo on the Kubota's is 14 amps. Exceeding a 14 amp draw will discharge the battery faster than the dynamo can recharge it.
   / WORK LIGHTS #8
I should never do multiplication without a calculator. /forums/images/graemlins/smile.gif
   / WORK LIGHTS #9
Funny, but I just came to the site to see if anyone hooked up a light recently. I just hooked up a 35Watt to my ROPS, but using a seperate bracket. My tractor will not fit in the garage with the ROPS up, so I use it with it down. In fact the bracket is removavble because with it mounted it is too high to get in my 7 foot door. I know I shouldn't run with the ROPS down, but it just gets in the way too much. I spliced my light into the rear running lights so I could use the main switch.
Question - I gues Kubota does not use a grounded system since there are two wires to all the lights. The light I bought was for a grounded system. I connected the ground to the light mounting screws. Any comments?
B7800, SB, York Rake, RM, FEL w/ teeth, 145 hours of fun /forums/images/graemlins/smirk.gif
   / WORK LIGHTS #10
Two things: Just went outside and tried the single 35 Watt light - Wow! Last winter I blew my 1/4 mile driveway using the light from the amber turn signals with the 35W light I think I will enjoy this much more.
Also, I got my Fluke out and verified that the wires under my B7800 seat are for accesories and the Black is grounded to the chasis, so I take back what I said about an ungrounded system. I guess they just want to make sure of a good circuit which will not be affected by corrosion.
I look forward to the first snow - oh yeah and the last in May too! /forums/images/graemlins/smile.gif
   / WORK LIGHTS #11
Try a set of these lights from Wal Mart if you want to see things cheaply. I bought the large 100 watt halogens for $17.00 apiece. the smaller 55 watt unit facing to the rear were $20.00 for the set. What a difference a little light makes at night. The bar that the lights are attached to is a simple side bed frame rail. I bent the square bolts that attach it to the ROPS. It was pretty simple to make and install. All the grounds are screwed to the bed rail.
   / WORK LIGHTS #12
Dean,
Yes the two forward facing lights are magnetic ones that I picked up at Wal-Mart last year. They don't seam to stock them at mine this year though as I was looking the other day as I need a replacement bulb for one of my lights.
I had bought the one facing rear as a pair before I found the magnetic ones, so I just ended up using it on the rear.
I take my lights off during the Summer as it's light enough for anything I want to do after work. Of course Winter is another story since it is dark when I get home from work.
If you are interested in my plow setup, you can review this thread from a while back.
BX1800 vs Garden
   / WORK LIGHTS #13
Speaking of work lights, I've been meaning to post this update to my "Modified FEL Bucket" post in August:
I've been moving things around at night lately so I decided to add lights to my earlier modification. I added two lights to the bucket support, one on the rear, and a cigarette-lighter socket for additional stuff. The lights are standard off-road lights from Napa Auto Parts. The front and rear lights are controlled by two toggle switches I added to the dashboard. The wiring on the FEL bucket is concealed and protected in 1/2" EMT conduit. The wiring runs along the underside of one of the FEL support arms protected by some salvaged braided-steel pneumatic tubing. It eventually hooks up to the Aux lights wire under the seat.
The standard BX2230 lights just light up the back of the bucket. With these I can easily see everything in front of the tractor. The bucket can be curled to point the lights up or down.
   / WORK LIGHTS #20
i ordered my bx 23 with a rear work light but they were out of the bx model so they gave me the l series work light kit part # td060-91001 about 70.00 its rectangular instead of round liked it so much i ordered 2 more and mounted under the top of the rops comes with bracket ,u-bolts wire harness and there is a switch on the back of the light....like night and day difference in forward and rear lighting.will post pic soon
Wagon Wheel Rocking Chairs (A55758)
Wagon Wheel...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
flatbed trailer 24ft (A56857)
flatbed trailer...
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
2015 Peterbilt 579 T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Peterbilt 579...
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
