Would it work to use a billiards table slate top piece for a welding table surface?
   / Would it work to use a billiards table slate top piece for a welding table surface? #1
jimgerken
Minnesota
John Deere 3720
I have a chance to get for free a couple 3' x 4' pcs of 1 inch slate from an old pool table. Thought it might make a super nice flat welding table top surface. What do you think? Would it shatter from the heat of welding, or would it survive OK, assuming I don't hit it with the torch directly?
   / Would it work to use a billiards table slate top piece for a welding table surface? #2
I think any high heat would start the slate to delaminate.
   / Would it work to use a billiards table slate top piece for a welding table surface? #3
The slate on a Pool Table can be broken fairly easy. Slamming a cue ball on the table will crack the slate. When installing a new slate on a table, the installers take real care when installing.
   / Would it work to use a billiards table slate top piece for a welding table surface? #4
If it's cheap enough get it. Put a 1/2' sheet of durorock on top and weld away. When the cement board goes - get another one. That's what I use on a wood top table - never had a prob.
   / Would it work to use a billiards table slate top piece for a welding table surface? #5
Consider pouring a cement table top?
   / Would it work to use a billiards table slate top piece for a welding table surface? #7
I wouldnt either. Ive had molten steel blobs drop on the concrete floor and you get a pop and a little crater in the drive the sizeof a quarter.
   / Would it work to use a billiards table slate top piece for a welding table surface? #8
The advantages to having a steel table are heat resistance, you always have a ground, clamping surfaces just to name a few.
The advantages of the slate- it's free, it's straight/flat.
I have used a piece of 3/4" plywood on saw horses in the past because that was all I had at the time. It worked, sort of.
I would try to sell the slate and put the money toward some steel plate.
   / Would it work to use a billiards table slate top piece for a welding table surface? #9
   / Would it work to use a billiards table slate top piece for a welding table surface? #10
The advantages to having a steel table are heat resistance, you always have a ground, clamping surfaces just to name a few. The advantages of the slate- it's free, it's straight/flat. I have used a piece of 3/4" plywood on saw horses in the past because that was all I had at the time. It worked, sort of. I would try to sell the slate and put the money toward some steel plate.
Bingo! Steel plate, no fuss, no bother, works every time.
2014 Chevrolet Tahoe SUV (A55853)
2014 Chevrolet...
2024 John Deere 872GP Articulated Motor Grader with GPS Package (A52377)
2024 John Deere...
GRINDER (A55745)
GRINDER (A55745)
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
2016 Ford SD Dump Truck (A52377)
2016 Ford SD Dump...
Willmar 4550 Wrangler Articulating Loader (A55314)
Willmar 4550...
