Would it work to use a billiards table slate top piece for a welding table surface?
   / Would it work to use a billiards table slate top piece for a welding table surface? #1
jimgerken
Minnesota
John Deere 3720
I have a chance to get for free a couple 3' x 4' pcs of 1 inch slate from an old pool table. Thought it might make a super nice flat welding table top surface. What do you think? Would it shatter from the heat of welding, or would it survive OK, assuming I don't hit it with the torch directly?
   / Would it work to use a billiards table slate top piece for a welding table surface? #2
I think any high heat would start the slate to delaminate.
   / Would it work to use a billiards table slate top piece for a welding table surface? #3
The slate on a Pool Table can be broken fairly easy. Slamming a cue ball on the table will crack the slate. When installing a new slate on a table, the installers take real care when installing.
   / Would it work to use a billiards table slate top piece for a welding table surface? #4
If it's cheap enough get it. Put a 1/2' sheet of durorock on top and weld away. When the cement board goes - get another one. That's what I use on a wood top table - never had a prob.
   / Would it work to use a billiards table slate top piece for a welding table surface? #5
Consider pouring a cement table top?
   / Would it work to use a billiards table slate top piece for a welding table surface? #7
I wouldnt either. Ive had molten steel blobs drop on the concrete floor and you get a pop and a little crater in the drive the sizeof a quarter.
   / Would it work to use a billiards table slate top piece for a welding table surface? #8
The advantages to having a steel table are heat resistance, you always have a ground, clamping surfaces just to name a few.
The advantages of the slate- it's free, it's straight/flat.
I have used a piece of 3/4" plywood on saw horses in the past because that was all I had at the time. It worked, sort of.
I would try to sell the slate and put the money toward some steel plate.
   / Would it work to use a billiards table slate top piece for a welding table surface? #9
   / Would it work to use a billiards table slate top piece for a welding table surface? #10
The advantages to having a steel table are heat resistance, you always have a ground, clamping surfaces just to name a few. The advantages of the slate- it's free, it's straight/flat. I have used a piece of 3/4" plywood on saw horses in the past because that was all I had at the time. It worked, sort of. I would try to sell the slate and put the money toward some steel plate.
Bingo! Steel plate, no fuss, no bother, works every time.
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
Electric Mobility Scooter (A54815)
Electric Mobility...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A55852)
2016 Autocar...
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
2006 FORD F-250(INOPERABLE) (A53843)
2006 FORD...
