Would You Accept This As New
   / Would You Accept This As New #81
When I lived downstate I would haul my tractor 160 miles one way to the location here thru slop and rain on the high way. This went on several times a year for appox 20 years. I have the same tractor today and have never had an electrical problem with it. My battery sits behind the front grill and I have never saw any salt or mud on it, just a lot of dust. If there was rust on the chrome parts of your tractor it did not come from this trip.Good Luck on whatever you do
   / Would You Accept This As New #82
I think the older the tractor the less problematic... some of today's tractors with tier IV emissions and electronics are very complicated and one sensor malfunction can make the tractor nearly unusable... which is amazing for the way we think if Diesels...
Many members with the early BX series tractors found out the hard way that even a little rain water or washing the tractor could lead to a no start condition... the blinker and lamp switches would short out just from rainwater...
   / Would You Accept This As New #83
They cannot be to water sensitive with the 100's you see sitting out side on the lots. I saw a load today on a truck going down the road in a rainstorm. Only thing covered on them was the plastic on the seats
   / Would You Accept This As New #84
   / Would You Accept This As New #85
I bought a new BX several years ago. I don't know how, but the engine and compartment was covered with what looked like a salt residue. I can't image how it got that way but kept it. It also had a leak in the hydraulic connections behind the battery compartment. The oil ran down everywhere and made a ****-of-a-mess. Some of the foam insulation was coming off. The dealer was of no help in any of this. I made all the repairs myself but was not happy about it. My next purchase was from a different dealer.
   / Would You Accept This As New #86
Ultrarunner,
I observed this blinker issue, myself, in 2010, on some (then) late model BX's, on a (used-only) Kubota dealer's lot.
I saw a BX, outside, with a blinking turn signal, mounted on the (left?) rear fender. I tried everything I could to turn it off, but it just kept blinking--s-l-o-w-l-y--like the battery was just about dead. I called him--he seemed to have no clue about the issue....
I assumed perhaps the rain had shorted something, so it's good to have confirmation, but disappointing to learn it's apparently what, in the automotive business, is called a "pattern failure."
I'd say that that known problem lends credence to a concern about the effects of a high-speed salt water "bath," if a gentle rain was enough to short out the blinker on a 2-3 year old tractor.
To paraphrase The Rolling Stone's "Miss You": "You know - (tractors) will come and go - They're just like streetcars..."
Personally, as stated previously, I'd skip this salty surprise--but best of luck to kcender, whatever he decides.
My Hoe
   / Would You Accept This As New #89
Just from my years of negotiating things I would have my opening statement to the guy, and before you looked at the tractor to be something like "I'm glad I have the option to decline if it's not up to snuff. This issue has had me very concerned".
It sets the stage in case you don't like it and gets his mind in the right direction in case you say no. Every dealer has been down this path before so they know the drill and he probably knew you would be concerned the moment that tractor rolled in. He won't let on because he wants you to want it and make his life easier. He knows he screwed up but that's just my opinion.
My free advice is, if it's not EXACTLY what you wanted and expected, don't take it. Act in haste, repent in leisure comes to mind.
   / Would You Accept This As New #90
Not sure who your dealer is, I know two here in NS that are pretty good from what limited business I've done with them.
To me the real issue is wanting the tractor "NOW", but not remembering it is winter time in Canada. I see this issue on other farm boards, relating to combines, balers and other equipment that may never even see snow let alone driving down a salty road at 70 MPH on a truck. General consensus, assume if you order something during the winter, it will be shipped on an open truck on crappy roads and blasted with salty brine, sand and water forced in places that don't need it.
I wouldn't be happy with the salt bath either, but if you saw your newly delivered tractor nice and shiny (even after being cleaned of salt) and not filthy you probably wouldn't of even asked about it. The dealer should be deliver a nice and clean new tractor. I don't think there will be any serious problems anyways, but I do agree it's not a "desired occurrence"
I've been looking at new M series, they all arrive in crates an get assembled on site....
Hope they look after you.
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
2017 John Deere 8370RT Track Tractor (A53485)
2017 John Deere...
Case TV380 (A53317)
Case TV380 (A53317)
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A55852)
2016 Ford F-550...
2024 ArmorLite Aluminum End Dump Trailer (A55315)
2024 ArmorLite...
2005 Toyota Highlander SUV (A55853)
2005 Toyota...
