Here's what I've experienced so far with the implements.
I used the snow blower a lot this winter and it worked great. I used to blow out sheer bolts all the time with my other blower but never blew a single one this year. I can't say why it's different - perhaps I just got lucky. I did pick up a big rock and broke the auger drive chain. The local JD shop had a replacement chain, and now I have the old one tucked away as a spare. I love the hydraulic chute rotation - it's fast and doesn't get jambed by snow buildup which my other blower did. I also really like the extra width. Unless I'm trimming back the snow banks, I can now clear my road in one run out and back. Before it took at least two full runs if not more. Snow blowing is also one place where the heated cab really shines.
The back hoe works great and has received a lot of use this spring. The rod on one of the cylinders was gouged by a shipping strap, but that was replaced by the dealer under warranty. I also had trouble from the start with the thumb foot peddle hydraulic control. It would not reliably pop back to an "off" position. At first I thought the linkage was just cruded up, but after more investigation it became clear that the control valve was sticking. My dealer was very helpful in walking me through a few experiments to see if we could free up the valve, but they did not work and Bradco just sent a replacement valve. I installed it the other day and it works great. This particular hoe sat in the dealer's yard for some time before I bought it and I think that valve just got cruded up.
Now that the valve is working, however, I have another problem. While diging out a big rock I managed to clamp the rock against the thumb cylinder and crack the welded hydraulic line fitting. The rock protruded just right, and next thing I knew hydrailic fluid was spraying all over the place. This one was all my fault and I'm still trying to sort out whether it can be welded or if I should just replace the cylinder. In the mean time I have removed the cylinder and pinned up the thumb.
I also just finished swapping out the seat on the backhoe. I'm 6' 2" and have long legs and the seating position is pretty cramped for me. I don't fit in a lot of cars either. Plus, I'm not a super flexible person (no Yoga here) and my legs just don't bend the right way to sit comfortably and operate the thumb foot peddle. I found a seat that sits up almost 8-10 inches higher than the original and it's a much more comfortable position now. I'll be doing more digging in the next weeks and will get some real seat time on it.
So, I've had some backhoe issues, but two are my problems, not the backhoes, one was shipping/handling damage and was taken care of, and the other was a left-out-and-not-used-for-too-long issue and was taken care of.
As for operations and performance, I remain very happy. I love the extra reach of the 11' hoe, and the digging power is the most you can get without going to a dedicated TLB or excavator.
Oh, one other thing - I figured out how to attach the hoe without dismantling and removing the tractor 3PH. All that was needed was to replace the two pins/cotter pins that anchor the sway links with a pin that has a handle on the end and can take a snap clip so it can be removed easily. To put on the hoe, you pull the two new pins and bring the draws bars and swaylinks together in a bundle and strap them with a bungie. In this position they fit easily in the space between the 4 point hoe mount frame. There is even room to leave the hydraulic top link attached. This makes getting the hoe on and off MUCH easier.
I've only used the
chipper a few times, but so far so good. The larger
chipper coupled with 50 PTO HP kicks butt. However, we did manage to feed it some real big hard maple and get the feed control to pause a few times to let the tractor catch up.
The quick-hitch loader is excellent too. It's great being able to switch easily between the bucket, forks, and grapple.
I haven't used the mower yet, and probably won't until July after the ground nesting birds have done their thing and are out of the grass. That should be around the 200 hr report card if thinks keep going as they have......
