Wrong size tube, now what to do?
   / Wrong size tube, now what to do? #1
Deere Dude
Elite Member
Beaver Dam Wisconsin then to Hohenwald, TN
John Deere 3720
I have a JD Garden Tractor that used a 18x8.50x8 front tubeless tire. It has two old plugs that are slightly leaking. I need to add air every other day. I bought a new tube on Amazon and came in today but the size I ordered was correct but I received a 18x8.50x9.50R8 with TR13 valve ( Whatever that means).
The question is, do I need to send it back and hope the numbers match up next time? I did plan on putting a new plug next to the old ones and cross my fingers and hope it seals. I just want a back up plan in case everything goes south on me.
   / Wrong size tube, now what to do? #3
use the tube, it fits both 18x8.50-8 and 18x9.50-8 tire sizes.
   / Wrong size tube, now what to do? #4
Use the tube but I found its really a poor band aide for a new tire. I have heard every reason that can come up to use tubes and really try not to if I can help it. It simply adds to the cost and cant plug them anymore.
   / Wrong size tube, now what to do? #5
Since most tires these days are tubeless, inner tubes are getting to be a rare commodity.
Added to that most are offshore sourced and come with built in leakage.
Seems that offshore rubber is porous.
   / Wrong size tube, now what to do? #6
2 tire stores I use for repairs use Korean tubes exclusively. No problems.
   / Wrong size tube, now what to do? #7
The TR13 refers to the type of valve stem. Meaning it's short, rubber and for a 1/2" rim hole. There must be 20-30 different types. :rolleyes:
   / Wrong size tube, now what to do? #8
Make sure the rim is smooth. Sometimes there are spot welds and a weld where the rim is put together. Smooth out any weld slag or buck shot. Tubes are the way to go.
2012 Jaguar XJ Sedan (A50324)
2012 Jaguar XJ...
2019 Dodge Journey Crossroad SUV (A50324)
2019 Dodge Journey...
McDon 75D Flex Draper Head (A52349)
McDon 75D Flex...
2013 Cadillac SRX SUV (A50324)
2013 Cadillac SRX...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
