Wrong size tube, now what to do?
   / Wrong size tube, now what to do? #1
Deere Dude
Elite Member
Beaver Dam Wisconsin then to Hohenwald, TN
John Deere 3720
I have a JD Garden Tractor that used a 18x8.50x8 front tubeless tire. It has two old plugs that are slightly leaking. I need to add air every other day. I bought a new tube on Amazon and came in today but the size I ordered was correct but I received a 18x8.50x9.50R8 with TR13 valve ( Whatever that means).
The question is, do I need to send it back and hope the numbers match up next time? I did plan on putting a new plug next to the old ones and cross my fingers and hope it seals. I just want a back up plan in case everything goes south on me.
   / Wrong size tube, now what to do? #3
use the tube, it fits both 18x8.50-8 and 18x9.50-8 tire sizes.
   / Wrong size tube, now what to do? #4
Use the tube but I found its really a poor band aide for a new tire. I have heard every reason that can come up to use tubes and really try not to if I can help it. It simply adds to the cost and cant plug them anymore.
   / Wrong size tube, now what to do? #5
Since most tires these days are tubeless, inner tubes are getting to be a rare commodity.
Added to that most are offshore sourced and come with built in leakage.
Seems that offshore rubber is porous.
   / Wrong size tube, now what to do? #6
2 tire stores I use for repairs use Korean tubes exclusively. No problems.
   / Wrong size tube, now what to do? #7
The TR13 refers to the type of valve stem. Meaning it's short, rubber and for a 1/2" rim hole. There must be 20-30 different types. :rolleyes:
   / Wrong size tube, now what to do? #8
Make sure the rim is smooth. Sometimes there are spot welds and a weld where the rim is put together. Smooth out any weld slag or buck shot. Tubes are the way to go.
2014 International Derrick Digger Truck (A55973)
2014 International...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
BOMAG BW213 SMOOTH DRUM ROLLER (A58214)
BOMAG BW213 SMOOTH...
2019 CATERPILLAR 259D SKID STEER (A52705)
2019 CATERPILLAR...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
2017 Mitsubishi Outlander AWD SUV (A56859)
2017 Mitsubishi...
