Wrong size tube, now what to do?
   / Wrong size tube, now what to do? #1
Deere Dude
Elite Member
Beaver Dam Wisconsin then to Hohenwald, TN
John Deere 3720
I have a JD Garden Tractor that used a 18x8.50x8 front tubeless tire. It has two old plugs that are slightly leaking. I need to add air every other day. I bought a new tube on Amazon and came in today but the size I ordered was correct but I received a 18x8.50x9.50R8 with TR13 valve ( Whatever that means).
The question is, do I need to send it back and hope the numbers match up next time? I did plan on putting a new plug next to the old ones and cross my fingers and hope it seals. I just want a back up plan in case everything goes south on me.
   / Wrong size tube, now what to do? #3
use the tube, it fits both 18x8.50-8 and 18x9.50-8 tire sizes.
   / Wrong size tube, now what to do? #4
Use the tube but I found its really a poor band aide for a new tire. I have heard every reason that can come up to use tubes and really try not to if I can help it. It simply adds to the cost and cant plug them anymore.
   / Wrong size tube, now what to do? #5
Since most tires these days are tubeless, inner tubes are getting to be a rare commodity.
Added to that most are offshore sourced and come with built in leakage.
Seems that offshore rubber is porous.
   / Wrong size tube, now what to do? #6
2 tire stores I use for repairs use Korean tubes exclusively. No problems.
   / Wrong size tube, now what to do? #7
The TR13 refers to the type of valve stem. Meaning it's short, rubber and for a 1/2" rim hole. There must be 20-30 different types. :rolleyes:
   / Wrong size tube, now what to do? #8
Make sure the rim is smooth. Sometimes there are spot welds and a weld where the rim is put together. Smooth out any weld slag or buck shot. Tubes are the way to go.
2017 Hitachi Zaxis ZX130 LCN-6 Hydraulic Excavator (A57453)
2017 Hitachi Zaxis...
LOT: Welding Power Leads, 220V Electrical Cord (A59076)
LOT: Welding Power...
2011 Ford F-750 Etnyre 2,000 Gallon Asphalt Distributor Truck (A56858)
2011 Ford F-750...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
SKID STEER ATTACHMENT HAMMER (A58214)
SKID STEER...
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
