WWF-Does it cause rust?
   / WWF-Does it cause rust? #21
Soundguy said:
I know the hooterites (spelling?)...
That's my favorite sect...
   / WWF-Does it cause rust? #22
digger2 said:
Soundguy,
Oh man,dont know how i missed that.Guess i'll be checking that out too
while i'm "weight shopping"......But wasnt that stuff (non toxic AF) pretty expensive when it first came out? Seems to me it was about 91-92 when it first appeard on the shelves and a guy i worked with back then said it was expensive then so i figure its gotta be pretty salty now....Oh what the hay,
i'm prob only gonna do it once so whats a couple of bucks...thanks.
it's way cheaper than beet juice... and remember.. you will be mixing it with water.. only got to add enough AF to prevent tire from freezing solid...
soundguy
   / WWF-Does it cause rust? #23
You may have them confused with a different sect....
jb
   / WWF-Does it cause rust? #25
You can get RV anti-freeze. That's made from propylene glycol. In the local walmart the Prestone brand is about $4.50 or so per gallon. And it's good to 0F. It's considered to be non-toxic by the FDA or EPA or one of those gov't agencies.
You can also get propylene glycol in various brands at well supplied plumbing distributors. If you buy in qty and then dilute it down to 0F it's just a few pennies more than the walmart Prestone.
Home Depot in NJ here sells some RV anti freeze also but I found it to be much more expensive than the other options.
   / WWF-Does it cause rust? #26
Yep.. holding tank AF...
soundguy
   / WWF-Does it cause rust? #27
I think it works out to almost double the cost of WWF with no real benefit to justify the extra expense. It does weigh a tad more but not enough to justify the extra cost.
   / WWF-Does it cause rust? #28
SCDolphin said:
Get "Rim Guard" beet juice or put tubes and fill the tubes. I would never want to use CaCl2
I love the fact that people think "Rim Guard" is everywhere. The closest I've found it in my area is over 150 miles away. I've talked to some local tractor dealers and they dont seem to be interested in switching from CaCl. I'm guessing they are making money selling new rims to people.
Wedge
   / WWF-Does it cause rust? #29
Is not the main goal to add weight?
CaCl2 weighs 13 lbs per imperial gallon.
WWF weighs around 8 lbs.
Put tubes in if you are concerned about rim corrosion.
My 35 year old IH454 has salt water in the rear tires (with tubes) and original rims.
   / WWF-Does it cause rust? #30
We have Mennonites and Amish of several orders around here. Some of the Amish have headlights, brake lights, turn signals, and strobe lights on their buggies plus diagonally striped reflective tape. The ones that live nearest me can't even use a SMV symbol, just the black reflective tape, and have staggered height kerosene lanterns on the buggy so you can see them coming at night. Those of you who have Amish neighbors -- ask them about the Swartzentruber Amish and see what they think of them. Around here the other Amish treat them like second class citizens.
The more progressive groups can set up a business which is allowed to own things like phones and computers, but they can't own them personally. They can use certain machines in their business or farming, but not others. It all depends on what their bishops rule at any given time and whether or not the individual person cheats on the rules. The guy who runs the sawmill nearest me can have a 200 hp Cummins diesel running the circular saw to make lumber, but isn't allowed to use a chainsaw to shorten the logs because it isn't stationary. The guy who runs the bulk food store can have electric coolers outside the store and computers in the store, but their phone has to be a community phone in a separate building and the lighting in the store has to be from gaslights. The electricity is from their generator, not the grid.
New/Unused 20x30 All Steel Carport (A54865)
New/Unused 20x30...
2018 PETERBILT 579 DAY CAB (A56129)
2018 PETERBILT 579...
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
2018 Sea Pro Boat with S/A Trailer (A55758)
2018 Sea Pro Boat...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A53421)
2023 Caterpillar...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
