X300R cutting problem
   / X300R cutting problem #11
Just found that same quote in owners manual.
On 42 mulching mower, blades are marked right and left on bottom side of each blade. Make sure to install correct blade to right and left sides of deck.
So that tells me my deck has opposite direction blades. I wonder if I could have gotten blades for a x300 and perhaps they do not spin counter on those? Now I need to track down the proper blades
When I got new blades for mine, I don't recall any caution about right/left.
   / X300R cutting problem #12
Here is a video showing the inner workings of the X300R that exhibits the counter rotating blades feeding a built-in blower system to bag the lawn clippings.
JOHN DEERE X3R - YouTube
Apparently comparing to a different Deere lawn mower for comparison.. adds some confusion..
Well now it makes sense
   / X300R cutting problem #14
my deck is the 48 inch one
correct blades ordered
   / X300R cutting problem #16
You could roll the belt clockwise (from the top) and see if your cutting edges are forward. So a 300R is a different animal than a 300. For those that have the 42M (mulch deck) on a 300, the principal is the same as a 300R as the blades counter rotate. I'd really have to assume that the belt couldn't get mixed up. So when you get blades for your 300R, be sure you get the ones you want. They I believe make a mulch blade as well as the standard and hi lift options.
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2015 UTILITY 48FT REEFER TRAILER (A59575)
2015 UTILITY 48FT...
New/Unused Quick Attach Wood Chipper (A57454)
New/Unused Quick...
2014 GMC Terrain SUV (A56859)
2014 GMC Terrain...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
