jaydee325
Veteran Member
- Joined
- May 21, 2013
- Messages
- 1,204
- Location
- Casco, Mi
- Tractor
- John Deere X584 Garden Tractor & LS R3039H
I'm not familiar with your tractor so I can't say which filter causes the most oil loss.
Putting a vacuum on the fill port will not suck oil out of the sump if the oil level is below the fill port.
Unless you have a filter cart, you cannot filter the oil well enough to be useful. Hydraulic systems require oil that is filtered down to the micron level.
When I changed my filters, I had a 2.5 gallon jug of hydraulic oil on hand just in case. I pre-filled each filter as much as I could with clean oil and then I was ready with a large drain pan. I quickly spun the old filter off and just dropped it in the large pan then then spun the new filter on. I lost a total of 2 quarts at most. Large pan prevented any mess as well.
