Yanmar 1602D starting issues
   / Yanmar 1602D starting issues #11
Do you currently have the starter off the tractor? If the solenoid only clicks, you have found at least a part of your trouble. Have you verified the battery has over 12 volts? As Norm and others have said, you may have a bad solenoid, and a connection issue as well.
You're homing in on the issue. Keep with it. Check the fusebox, as well, for your other electrical issues. If you've lost power to the rest of the tractor, start easy and work your way through it.
   / Yanmar 1602D starting issues #12
so far,
the starter solenoid will click, but actually doesn't move enough to engage the gear or complete the circuit for the starter.
Are you futilely attempting to repair this tractor without a volt/ohm meter:confused:? How much voltage is in your battery?
   / Yanmar 1602D starting issues #13
Thats a must. The same thing was going on with my starter. After I disasembled it Blew and cleaned the Brushes and Dust out it's been fine for 3yrs.And my Throw Out Gear was Sticking Also And Not engaging the Fly wheel. A little Steel Wool and oil took care of that ;)
Carey
2012 TAKEUCHI TL12 SKID STEER (A60429)
2012 TAKEUCHI TL12...
Ford 8510 (A53317)
Ford 8510 (A53317)
(INOP) JOHN DEERE 544 AA WHEEL LOADER (A60430)
(INOP) JOHN DEERE...
2018 JOHN DEERE 323E SKID STEER (A60429)
2018 JOHN DEERE...
207270 (A52708)
207270 (A52708)
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
