spyder2
Gary
Are you sufficiently comfortable that you followed as close as possible to the same procedure in testing the compression on both cylinders? The reason why I ask this is that I agree with the posts on using the rubber tipped compression tester. It could be that you got close to the same readings because that is as hard as you were able to hold the tester down. If you got the 300 reading on the front cylinder then compression is probably not your problem. Also did it feel to you as if one of the cylinders was not blowing as hard as the other one or did anything sound different when testing either one? I would first ensure that the pump is in good working order and that the injection timing is set properly before tearing into the engine. Good Luck
